help with momo hub
anyone have any good techniques on how to get a really stubborn momo hub off? mine seems to be stuck in placei tryed using some chemicles to loosen it but no dice...anyone got any ideas
...must not be the right hub if its not comming off its usually pretty easy unless the shaft had been tampered with.....give it a few yanks ... and see what happens!!!
Take a crowbar to it if all else fails, are you trying to take it off with the steering wheel attached or not, if not you can get more leverage with it, but be careful. I would use something to try and pry it off, or PB nut blaster.(WD40)
go to your local pep boys...they have this thing that is called a "steering wheel hub puller" you can rent it from them. and its pretty easy to use. make sure to get the slide hammer with it too.....
RGuo921
Sep 16, 2008 09:39 PM
metalgears
Jul 25, 2004 12:08 PM
