heptagon lug key broke what to do!!! please help
Old May 4, 2004 | 04:37 PM
gaydm.accord's Avatar
Default heptagon lug key broke what to do!!! please help
ok heres the problem... we tried to use the key to take off one of the lug nuts and it broke the damn key. does anyone else have any suggestions on taking these damn lug nuts off before i start dremeling? we've checked everywhere for the key but nobody has them and the only place that does have them will only sell it as a set for 50 bucks for the complete set. BTW we've also tried hammering in standards and metrics and both sets will not take these damn things off.
Old May 4, 2004 | 04:40 PM
Apollo's Avatar
Default Re: heptagon lug key broke what to do!!! please help (gaydm.accord)
vice grips or channel locks. Then replace it with a normal lug nut.
Old May 4, 2004 | 06:50 PM
vice grips doesnt work , i've got panasports on the car also so that give you guys and idea of how much space i have to work with
Old May 5, 2004 | 04:28 AM
Apollo's Avatar
search the internet to buy the single key for it.
or maybe try to find someone who might have one you could borrow.
Old May 5, 2004 | 10:22 AM
Default Re: (Apollo)
hence the thread =p anyone have one in so cal?
Old May 5, 2004 | 02:51 PM
Kal's Avatar
Kal
Default Re: (gaydm.accord)
attach a socket to it with loctite or something and spin it off that way.
Old May 6, 2004 | 08:06 AM
IS3Fifty's Avatar
Default Re: (Kal)
samething happened to me today, except I was putting them on
Old May 6, 2004 | 08:49 AM
BeerMan's Avatar
Default Re: (TODAeg6)
how about one of these?
http://gator-grip.com/
I think I've seen them at Sears.
Old May 6, 2004 | 11:28 AM
i gotta try that gator grip stuff
modified: i take that back gator grip seems to have a bad rep i think i might try and get a hold of bolt out by craftsman
Old May 6, 2004 | 12:30 PM
Rtype16's Avatar
Are you talking about the regular old hex key its like a size 17mm or something? You can buy them from snap-on or if you are really in a bind you can come to my work and I will help you get them off.
Old May 6, 2004 | 12:41 PM
no its a heptagon lug the key is a female thanks for the help
Old May 6, 2004 | 01:24 PM
Rtype16's Avatar
Hmm seven sides... Which lug nuts are you using?? Are you using Volk lug nuts?
You guys all know you don't have to torque down lugs nuts that tight. At least tight enough to break the key.
Old May 6, 2004 | 02:10 PM
its wheel mate... and my homie just bought the car and the owner wanted his rims back but we couldnt even take off the lug nuts so... he cant get his panasports back til we get the lug's to crack and the car also needs the axles changed... ARgH
Old May 6, 2004 | 03:14 PM
Cyphear's Avatar
weld a bar or something to the nut, then twist, overtightening the other lugs will also help, but hopefully not bend your rotor. you can try glue/jbweld, but i doubt it'd work. Another idea would be to make a mold and then have it cast, but thats too much work. Also, maybe cuting off the top of the lug nut might work.
Old May 8, 2004 | 12:46 AM
E-brake or Handbrake's Avatar
Default Re: (Cyphear)
After searching through literally 10 different stores for the key, I've finally found a place that supplies it! A place called PRESTIGE located in Huntington Beach, CA between Warner & Gothard.
Well after purchasing the key I returned back home and waited for my car to cool down before attacking the lugs. I managed to get one...yes, ONE lug off while the others remain on. I've even tried WD-40 to see if it'll loosen the grip. The key just smooths right over the lug nuts....
Man! These lugs are ****! Anymore suggestions?
Old May 8, 2004 | 01:56 AM
yoohoo's Avatar
bump for a solution!
Old May 8, 2004 | 02:02 AM
Default Re: (superbowlizghey)
GayDM
Old May 18, 2004 | 10:49 PM
Default Re: (Inconclusive)
CRAFTSMAN BOLT-OUT OWNZ ALL!
Old May 19, 2004 | 02:37 AM
georgelb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Inconclusive &raquo;</TD></TR><TR><TD CLASS="quote">CRAFTSMAN BOLT-OUT OWNZ ALL!</TD></TR></TABLE>
I concur
Old May 19, 2004 | 04:52 AM
4crx4me's Avatar
Default Re: (georgelb)
Not that this is any help but, when my McGard(sp) lug key broke we had to cut the lugs off with an air chisle. But that was only one lug per wheel.
Good luck. To anyone putting lug nuts on with an air gun
Old May 19, 2004 | 10:09 AM
Cyphear's Avatar
Default Re: (4crx4me)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4crx4me &raquo;</TD></TR><TR><TD CLASS="quote"> To anyone putting lug nuts on with an air gun </TD></TR></TABLE>
Not if you have a shitty one like me that only puts on like 85lb/ft at 125 (max) psi.
Old May 19, 2004 | 02:53 PM
vtec94civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by georgelb &raquo;</TD></TR><TR><TD CLASS="quote">I concur
yes that **** works and it does the job quick. i had kyokugens and they stripped on me so i went out and bought the sears bolt out and it worked perfectly.
Old May 19, 2004 | 03:39 PM
Default Re: (vtec94civic)
Wish that I have bought these sooner! I'll try to get a picture of those DAMN bolts--they are beyond stripped but gaydm and I managed to get the last few bolts off with the exception of 2.
gooberguy31
Apr 18, 2008 04:42 AM
jdmztrane
Apr 1, 2008 08:51 AM
crxsleeper210
May 16, 2006 05:01 PM
JDM Approved
May 4, 2005 10:49 PM
Homer_Simpson
Jan 23, 2002 08:39 PM
