Installing Neuspeed strut bar...
I am trying to install a neuspeed strut tower bar on my 91 LS, but am having some fitment issues. I jacked the car up on the drivers side, I heard this helps since the weight is lifted a bit. The bar fits on the passenger side, but the drivers side seems impossible to get to! (Clutch cable and other lines getting in the way) Any help? -Thanks
Does it matter if I jack the car up from the side? Or should it be in the front? Also, how do I get by the throttle cable, clutch cable? There is also a thick wire (wrapped with a small piece of green tape) that doesn't really move. -Thanks
I jack it up in front. The reason why you want to jack it up is so the bolts on the top hat don't stick out of the body.
As far as i can remember, I just put the throttle cable in between the legs of the neuspeed bar.
The thick wire with green tape... i had to remove it from its bracket. I think it's a 10mm bolt.
Modified by jonsteR at 7:02 PM 5/4/2004
Thanks man
. As for the clutch cable and throttle cable, did you just fiddle around with them to make space? Or is there a certain way they should be placed.
Yeah, just fiddle with those cables and see what works for you. You can route your clutch cable under your intake manifold so you won't have to worry about it, and it looks cleaner this way.
