B Series Header Question?
Old May 4, 2004 | 10:18 AM
The G2 Racer's Avatar
Default B Series Header Question?
I was told the a header from any B series will fit another B series. Is this true?
Like a B18C1 header fitting on a B18B.
Old May 4, 2004 | 10:21 AM
skip.two's Avatar
Default Re: B Series Header Question? (The G2 Racer)
a B series header should fit other B series from what i've read. do a search. there are plenty of posts that are similar to your question.
Old May 4, 2004 | 10:22 AM
BlownVR's Avatar
yes as long as its 90-93 and 94-01 because my friend got the 90-93 header and it didn't work on his 98 gsr motor... just my thought
Old May 4, 2004 | 10:26 AM
dunkd's Avatar
the flange on the head is the same but the lengths are different on some cars. like if u put a GSR in an EG then u need a b16 header for it to fit.
Old May 4, 2004 | 10:28 AM
skip.two's Avatar
Default Re: (dunkd)
well the GSR header is longer than a B16, so you might want to be careful with a lowered car. b16 would be a better choice (in the case of a height problem).
Old May 4, 2004 | 10:32 AM
Default Re: (jL iLLuZiOnz 9)
Thanks for the info guys.
What about the O2 sensor? Need some type of special tool to remove it?
Old May 4, 2004 | 10:39 AM
dunkd's Avatar
nope, just a wrench and some muscles
Old May 4, 2004 | 10:45 AM
Sketch_hs's Avatar
Default Re: (dunkd)
i used a gsr dc sports ceramic header on my b16 eg.
the header does hang low, but it's not to bad.
The header will NOT reach the stock cat, and the flange is "backwards"
you need a GSR type (all integra?) cat, hi flow cat, or test pipe to bolt up to standard civic exhaust (like stock or my RS*R)
good luck!
antcrxls
Jun 28, 2012 04:20 PM
sohcSUCKS
24
Mar 25, 2008 02:45 PM
yz125rider21
Feb 4, 2007 12:40 AM
maxxdout
Oct 4, 2001 09:08 AM
