Car warms up a lot quicker, its like i'm always trying to maintain temperature
Old May 4, 2004 | 08:47 AM
VNTEC's Avatar
B A N N E D
Default Car warms up a lot quicker, its like i'm always trying to maintain temperature
Ever since i boosted my car warms up REALLY quick, i noticed this since the first day i installed my turbo, but thats probably normal. I always have my fan on (just to maintain temperature) Sometimes when i do a pull, i can see it get noticable hotter and it will slowly start to go back down, it always seems like i'm fighting a battle to keep my car cool Whats going on guys? My air fuel ratios are 12.5 (+/- .5) while in boost. I dont think i'm running THAT lean now am i? Is this normal?
Old May 4, 2004 | 08:56 AM
RAWB's Avatar
Default Re: Car warms up a lot quicker, its like i'm always trying to maintain temperature (VNTEC)
FRESNO get pretty hot. How's your thermostat? Still using stock fans/radiator? Maybe try bleeding your cooling system. What are you using to monitor your A/F?
Old May 4, 2004 | 09:00 AM
SiRex91's Avatar
Default Re: Car warms up a lot quicker, its like i'm always trying to maintain temperature (RAWB)
Sounds like you need a new thermostat or your fans aren't turning on.
Old May 4, 2004 | 12:58 PM
VNTEC's Avatar
B A N N E D
Default Re: Car warms up a lot quicker, its like i'm always trying to maintain temperature (SiRex91)
Like i said my fans are always on, but the thermostat... Hmmm doesnt it stay open if its bad?
Old May 4, 2004 | 02:21 PM
VNTEC's Avatar
B A N N E D
Bump
Old May 4, 2004 | 02:32 PM
sporkcrx's Avatar
I think it can get stuck either way. I wonder if leaving the fan on while you're moving will prevent more airflow than take in?
Old May 4, 2004 | 03:25 PM
RAWB's Avatar
If it's staying stuck, then it won't allow it to go to the radiator for cooling.
Old May 4, 2004 | 05:01 PM
VNTEC's Avatar
B A N N E D
I'm using a techedge wideband with palm logger, so i should change thermostat?
Old May 4, 2004 | 05:31 PM
m R g S r's Avatar
Yea, change it, they are really cheap and easy to change, and you might as well change the coolant anyway.
JacobAF20
Honda Civic (2001 - 2005)
Sep 24, 2016 10:51 AM
cpierich
Feb 26, 2012 06:27 PM
JigsN Joints
Aug 18, 2011 12:32 AM
turbotime
Nov 14, 2005 12:45 PM
