arp head studs going into my dohc zc.......some ?'s
Old May 4, 2004 | 06:06 AM
redzcstandardhatch's Avatar
something different
Default arp head studs going into my dohc zc.......some ?'s
tonight and tommorrow, i'm gonna replace the blown head gasket on my dohc zc. i've done the whole job before, but i re-used the old head bolts, which were in TERRIBLE shape. 3 were badly corroded. i'm hoping that one just stretched. the headgasket is just leaking a little bit of coolant into a cylinder, not mixing coolant and oil. anyways. i have ARP head studs now, waiting to go into the car when i pull it all apart. the kit for the dohc zc isnt out right now, i called ARP directly. they said, as did Race Engineering, to use the kit for the VW jetta/gold 16valve, so i got that. supposedly the bolt are a bit shorter, and i was told to use loctite when i install them into the block, then torque everythind down when i put the head on. does this sound like a good way to do it? any help is appreciated. thanks very much-adam
Old May 4, 2004 | 10:15 AM
something different
bump
Old May 4, 2004 | 10:25 AM
APEX CRX's Avatar
Default Re: arp head studs going into my dohc zc.......some ?'s (redzcstandardhatch)
well as far as if the ARP kit is the correct one I dunno. But for sure use red loctite and torque in correct order.
Old May 4, 2004 | 10:43 AM
something different
Default Re: arp head studs going into my dohc zc.......some ?'s (APEX CRX)
i know the kit will work, i'm just wondering if the loctite on the studs (because they cant thread into to block all the way down) is a good idea. should i put lube and loctite on? does that work? i havent used too much loctite. sorry for the long initial post.
Old May 4, 2004 | 02:09 PM
something different
anybody got anything else to add? just wondering.
Old May 4, 2004 | 02:29 PM
APEX CRX's Avatar
well as far as putting lube on my ARP instructions did not specify to do so. Just the loctite from what I remember.
El pimp chulo
Feb 20, 2007 11:43 AM
junior40er
Jun 20, 2006 09:35 AM
crix351c
Dec 16, 2005 01:49 PM
JK_Motorsports
Jul 13, 2005 05:47 AM
cel_912
Mar 12, 2003 03:02 PM
