Exospeed Street CRX w/road wheels
Old May 4, 2004 | 02:40 AM
ExospeedAMcrx's Avatar
Default Exospeed Street CRX w/road wheels
Finally got a pic of the CRX with some road wheels. Didnt get a good pic on a leveled surface though.
Old May 4, 2004 | 02:42 AM
Default Re: Exospeed Street CRX w/road wheels (exospeedAMcrx)
totally gives a new personality with just different wheels.
Old May 4, 2004 | 03:16 AM
FURACERMAN's Avatar
Disgusting!
Old May 4, 2004 | 04:37 AM
ki3t's Avatar
This user can set his title.
Default Re: Exospeed Street CRX w/road wheels (FURACERMAN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FURACERMAN &raquo;</TD></TR><TR><TD CLASS="quote">Disgusting! </TD></TR></TABLE> So is your avatar Nice Rex.
Old May 4, 2004 | 05:10 AM
Ya@inlinePRO's Avatar
dope, whats the best time
Old May 4, 2004 | 06:11 AM
ebelp's Avatar
Default Re: (kwik2nec)
That thing doesn't look slow.
Old May 4, 2004 | 06:27 AM
havent taken it out yet. just put in the motor recently.
We'll be happy if it does low 12s. but aiming for some 11 sec time slips.
Old May 4, 2004 | 08:14 AM
cre18's Avatar
Default Re: (exospeedAMcrx)
good luck, looks like a monster
Old May 4, 2004 | 08:33 AM
Gabe_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">totally gives a new personality with just different wheels.</TD></TR></TABLE>
Agreed.
Looks good either way
Old May 4, 2004 | 08:35 AM
ORcivicsi's Avatar
Default Re: Exospeed Street CRX w/road wheels (Gabe_)
If i only still had my rex. Nice car. Engine work?
Old May 4, 2004 | 08:36 AM
LoSt is BlaCk's Avatar
Default Re: (cre18)
BOOOTTEEEFFFUUULLL!!!!!
Old May 4, 2004 | 09:02 AM
Default Re: Exospeed Street CRX w/road wheels (ORcivicsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ORcivicsi &raquo;</TD></TR><TR><TD CLASS="quote">If i only still had my rex. Nice car. Engine work?</TD></TR></TABLE>
THank you for the compliments.
Here's a picture of the engine bay if you guys havent seen it on the EF forum.
Here's the parts list.
Exospeed Stage 4 race block: D16A6 engine
-Arias 14:1 compression pistons 78mm
-RS Machines 78mm bore sleeved block
-Knife Edge Crank
-Eagle Rods
-everything else OEM Honda replacement parts
Exospeed Stage 4 Race head
-Exospeed sohc valvetrain, Ti retainers and perf. valve springs
-Street/Race port and polish
-Stainless Steel Valves
-AEM Cam gear
-Exospeed Stage 4 A6 Race cam
Transmission
- 1-2 Gear from 91 CRX Si
- 3-4 Gear from JDM ZC
- 5th Gear form 91 Si
Final Drive: Houseman Custom
Quaife LSD
Action 1MD clutch
Evolution Industries Alum Flywheel
Suspension:
Tokico shocks (temporary)
Ground control Adjustable Coil overs (temporary)
- Rear 1000lbs springs
SPC Performance front ball joint camber adjustment kit
SPC Performance Rear Camber adjustment kit
SPC Performance Rear Toe adjustment kit
SPC Performance Rear Lower Control Arm(silver)
Jimfab Front Crossmember
PROGRESS front LCA spherical bearings
Wheels:
Track: Bogart Litespeed 13x8 Drag wheels & 15x3.5 rear skinnies
Slicks: M&H 22x8x13 slicks and 22x3.5x15 skinnies
Street: Mugen RNR 15x6.5 Silver
Other Engine Accessories
SX Fuel Pressure Regulator
Steel Braided lines with Earl Fittings
Earl Fuel Filter
Greddy Catch Can
Jimfab rear and front mounts
C&R Radiator with Spal Slim Fan
Bisimoto Street Header
Edelbrock Intake Manifold
GSR Throttle body
OBD1 conversion
Hondata S200
MSD 6AL Ignition
NGK Plug Wires and Spark Plugs
Jet Hot Coated Valve Cover
Interior
Recaro Speed Racing Seats
SRR Ignition Switch
MOMO Race Steering Wheel
Tekniq Steering Wheel Quick Release system
Autometer Gauges
Exterior:
Fiberglass Hood Skin
Fiberglass Rear Hatch
All New Glass Replaced
Dzus Fasteners
All New bumper moldings
New Headlights
Modified by exospeedAMcrx at 7:58 PM 5/4/2004
Old May 4, 2004 | 09:18 AM
opi's Avatar
opi
sweet looking Rex, i like how it looks "both" ways
Old May 4, 2004 | 09:26 AM
90JPRCRX's Avatar
Smells like Tuna
wheres the vt3c y0
j/k
that thing on slicks looks scary mean
and what radiator did you guys use?, thats pretty small
Old May 4, 2004 | 09:33 AM
goforbroke's Avatar
MEAT PATTY
Default Re: Exospeed Street CRX w/road wheels (88JPRCRX)
How much does your rex weigh? Because low 12's to high 11's is pretty damn fast and I think I remember reading your setup somewhere. But I had no idea it was going to be capable of those types of times.
Old May 4, 2004 | 09:34 AM
976's Avatar
976
New User
Default Re: Exospeed Street CRX w/road wheels (goforbroke)
More pictures of the engine bay please!
Old May 4, 2004 | 10:21 AM
ok Ill update the post with the specs.
Old May 4, 2004 | 11:36 AM
743power's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">ok Ill update the post with the specs.</TD></TR></TABLE>
sohc power
Old May 4, 2004 | 01:35 PM
crx_91si's Avatar
Default Re: (x743x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x743x &raquo;</TD></TR><TR><TD CLASS="quote">
sohc power</TD></TR></TABLE>
represent'n that A6
Old May 4, 2004 | 01:59 PM
KiD Fr0m Da 516's Avatar
that crx is looking clean
Old May 4, 2004 | 02:10 PM
DagYo!'s Avatar
nice
Old May 4, 2004 | 05:03 PM
jarel's Avatar
Default Re: Exospeed Street CRX w/road wheels (DagYo!)
damn wil! the crx is looking good. Is that your old crx turned race car? Jared said you might roll out on Friday...if so, can't wait to see the car
jarel
Old May 4, 2004 | 05:05 PM
t-blizzard's Avatar
looks good.
Old May 4, 2004 | 05:28 PM
dc5 jared's Avatar
wil....hope you roll this beast out on friday..fuddruckers.
Old May 4, 2004 | 05:30 PM
92B18Bvx's Avatar
Default Re: (sleeper dc5)
how does the car run with out having the throttle cable hooked up?
