vss question
Old May 3, 2004 | 09:00 PM
jazz215's Avatar
Default vss question
just wondering if the vss from my auto tranny is usable on a 5spd tranny. tranny is for a 92-95 ex/si tranny if it matters. also do i need to crack open the tranny to install it?
Old May 3, 2004 | 09:05 PM
blackhatchy's Avatar
Default Re: vss question (jazz215)
im not too sure about the compatibility, but i do know you do not have o take apart the tranny. just unscrew it and it will pop out
Old May 3, 2004 | 09:06 PM
99blackcivicSi's Avatar
I am not 100% sure if it will work my initial thought is yes.
No you don't need to pull the case off to install it just unplug it and take out the 10mm bolts pull out put new one in and put the 10mm bolts back on and plug it up and your good!
Old May 3, 2004 | 09:25 PM
jazz215's Avatar
thanks guys, knowing i dont have to reopen the case makes me happy. just need to know the compatability now. i was thinking it would be the same.. but ..bump for some tranny experts.
EK FLY
Feb 18, 2005 03:29 PM
cr-x si
16
Jun 19, 2003 09:13 PM
jdmCivic925
May 25, 2003 12:51 PM
