itr ecu not working with ls vtec
Old May 3, 2004 | 08:58 PM
my_slow_civic's Avatar
Default itr ecu not working with ls vtec
i have an obd 2 integra ls. I did a ls vtec swap with b16 head intake, gsr cams, b18b fully built block. stock ls injectors, fuel rail and throttle body. the car runs great with the ls ecu. once i plugged in the itr. it boggs down when i try to give it gas, it throws codes and then stalls on me. i even disconnected the 3 wires i added and it still does the same thing. do i need to wire in something else? plus just to make sure where does the vtec pressure, solenoid, and knock plug into on a obd 2.
help please
Old May 4, 2004 | 05:49 AM
tgreaves's Avatar
Default Re: itr ecu not working with ls vtec (my_slow_civic)
What codes does it throw on you..
.M.
Jul 19, 2005 07:32 AM
CircuitFG
Jun 27, 2004 11:46 AM
my_slow_civic
May 5, 2004 08:45 PM
