Smoke from engine
Old May 3, 2004 | 07:24 PM
Jockdeeznutz's Avatar
Default Smoke from engine
I was driving then i smelled some burning. I noticed some smoke coming from the hood. It was white smoke. I searched and many people said white smoke= coolant. My oil temp on my cluster was all the way up. I need to narrow down what the problem is. Is my gasket busted, my thermostat gone bad?, or something else. My motor is not boosted and it has 80k. any info will help
thanks
Old May 3, 2004 | 08:20 PM
limpy's Avatar
Default Re: Smoke from engine (Jockdeeznutz)
sometimes the thermostat will stick causing it to overheat, this could intern bust your head gasket if it gets hot enough
Old May 3, 2004 | 09:11 PM
Default Re: Smoke from engine (limpy)
thanks anyone eles?
Old May 3, 2004 | 11:29 PM
poison's Avatar
inspect the engine bay and see where the leak is comin from. you're leaking and steaming off coolant.
Bigbassbillie
May 4, 2016 08:34 PM
jeresaur
Mar 13, 2011 05:00 AM
the_dxB16
Dec 25, 2008 01:23 PM
4dr*sleeper
15
Aug 1, 2005 02:08 PM
sambam27
Dec 5, 2004 09:39 AM
