NSX Air Conditioner Problem... Need Help!
We have a 1991 Honda NSX.
The problem is, its air conditioning system does not seem to work very well. The fan works but you cannot change the positioning of the air like directly to the face or to the foot...
Is this problem about the air conditioning computer or the positioning motor? in another way is this maybe electronical or mechanical problem?
Thanks for your help.
What happens when you press the MODE button? Pressing it will override the automatic setting and cycle through the foot, dash, and defroster vents and the display should indicate which vents are active.
it all seems to be active.
we took out the motor that does change the way of the air flow and it all works...
i cannot understand where the problem is...
wallow
14
May 31, 2020 01:50 PM
1991, ac, accura, acura, air, automatic, conditioner, conditioning, doesnt, mechanical, nsx, problem, problems, setting, work
