Fuel tank location question
Old May 3, 2004 | 04:01 PM
TnTWRX's Avatar
Default Fuel tank location question
Is the fuel tank located under the rear seat on a DC2?
I am contemplating recess mounting an amp under the seat perpendicular to the floor but was wondering what was under there.
Any help is greatly appreciated
Old May 3, 2004 | 04:06 PM
boostinb20vtec's Avatar
I am not totally sure if it is, but the fuel pump and in line fuel pump are.
Old May 3, 2004 | 04:30 PM
Weston's Avatar
The fuel tank is under the rear seats and extends into the rear cargo area. So, don't drill into the floor of the trunk unless you are 100% sure where the fuel tank is. People have drilled right into the tank before, and it's not an easy fix, since you can't just weld it shut.
The fuel pump is under the large round metal cover in the center under the rear seat. The other round cover is the fuel level sensor. There is no inline fuel pump unless you add one.
Old May 3, 2004 | 08:29 PM
TnTWRX's Avatar
Default Re: (Weston)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Weston &raquo;</TD></TR><TR><TD CLASS="quote">The fuel tank is under the rear seats and extends into the rear cargo area. So, don't drill into the floor of the trunk unless you are 100% sure where the fuel tank is. People have drilled right into the tank before, and it's not an easy fix, since you can't just weld it shut.
Thanks weston, that's what i needed
mars-EF-LS
Jan 1, 2008 09:59 AM
JeDPhelps
Feb 5, 2006 05:41 PM
1990 CRX Si
Jan 9, 2006 05:08 AM
dragracin247
15
Sep 2, 2005 08:15 AM
Ragezero76
Jul 19, 2004 05:09 PM
