rear strut bolt broke! HELP!
i just installed my front shocks/springs and then moved to the rear. i broke the head off the lower shock bolt.
i have function7 LCAs im gona be puting on so i already pulled the lca's off.
my question is im gona go buy 2 new bolts for the bottom if the shock.
will i need to buy a nut also?
i dont see a nut in the pic
please let me know asap i need to get these parts orderd
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">The nut is welded onto the shock itself.</TD></TR></TABLE>
this happened to me like one week ago well i dunno if i had the same problem, in my case the bolt (19) would not fuking come out then the nut welded onto the strut broke, god knows how so i jus said *** it and took it to a shop and they put it in for like 50 bux however now my ABS light is on i wana see what kinda imput u get on this asue i dint get ****
When I switched to using ITR LCA's, I had the nut chiseled off and used a M8x1.25 flange nut.
I actually like that better b/c it's easier to install the bolts without having to worry about the threads lining up or being damaged (altho it's pretty hard to damage the threads). You just push or whack the bolt through and slap the nut on the other side. Voila.
does ne1 kno how much a new bushing is for the back because they said wen i got mine put in that my bushing was melted around the bolt and since im thinkin of putting my stok springs back on when i sell the car im gunna need new bushings, so does ne1 kno???
Usdmowns
Sep 9, 2006 12:26 PM
TheHatchHog
10
Jul 29, 2004 07:15 AM
Jeff92NY
Sep 12, 2003 04:40 AM
