H22 Swap
Old May 3, 2004 | 01:36 PM
93blkdelsol's Avatar
Default H22 Swap
I finally blew the original engine in my Del Sol.. Now thinking about swapping to a H22 i know it will be a tight fit and will need new mounts, but does anyone know of anything else i will need or problems i might run into with the swap?? I would like to do this swap but if it will cause tooo much trouble i might have to settle for a B16a swap instead
Thanks!!!
Old May 3, 2004 | 02:09 PM
MadnessRacing's Avatar
Default Re: H22 Swap (93blkdelsol)
well the motor fits pretty good but youll have 2 little problems 1 is modify axles and 2 is open holes for the linkage but youll be very happy with the stock power, i got the alluminum billet mount kit for you,if you are interested letme know. good luck
doezitmater
Jun 30, 2007 09:34 PM
EG_Civic_Si
12
Sep 9, 2004 01:04 PM
NSTY Z33
Mar 14, 2004 10:20 AM
iwhichisme
Sep 28, 2002 02:06 PM
hondabadboy
Feb 18, 2002 10:12 AM
