hooking up vtec .. p08 to d15b
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by labatia »</TD></TR><TR><TD CLASS="quote">i need it for p08</TD></TR></TABLE>
Same thing.
VTEC solenoid = A4
VTEC oil pressure = D6
VTEC oil pressure (other) = ground
Same thing.
VTEC solenoid = A4
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">
Same thing.
VTEC solenoid = A4
VTEC oil pressure (other) = ground</TD></TR></TABLE>
Same thing.
VTEC solenoid = A4
i also had to do some weird wireing cause the original wires didnt connect to eachother......will the B16a even work in a '88 civic dx hatch?? or will i need to undergo a whole **** load of customizing?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxjon »</TD></TR><TR><TD CLASS="quote">say you dont have that plug that goes in to the solenoid how would you go at wiring it ?</TD></TR></TABLE>
To the solenoid or oil pressure switch? I had a plug for the oil pressure switch...and I just used a little clip for the solenoid wire.
To the solenoid or oil pressure switch? I had a plug for the oil pressure switch...and I just used a little clip for the solenoid wire.</TD></TR></TABLE>
got pics? i not sure about the oil pressure plug is that a a plug you added?
BUMP FOR DA MAN
I am putting that same engine in this weekend - I also have da P08 with the 1-wire O2 and some pics woud definitely be helpful
i have a d15b vtec with a po8 ecu in a 92 cx with a cx harness what do i need to add? can i get away with not adding plugs an just wiring it up to the solenoid and what not?
vtecn8ive
22
Aug 3, 2005 01:06 PM
