swaps for 85 crx si
Old May 3, 2004 | 10:17 AM
imasianman's Avatar
Default swaps for 85 crx si
Can I use the same mounts as if I was dropping the motor into an 88+ crx?
Old May 3, 2004 | 10:39 AM
I3ackfire's Avatar
Default Re: swaps for 85 crx si (imasianman)
NO...seperate mounts
Old May 3, 2004 | 04:09 PM
whizzlefist's Avatar
Default Re: swaps for 85 crx si (I3ackfire)
if yuo have an 85 si you own the lightest FI CRX ever made.... if you must swap a new engine in it the 86-89 integra d16a1 drops in you can allso get a 1g zc (not the 88-91 zc thats a 2g and the series after that is 3g zc) a 1g zc is almost identical to the d16a1 ther is a slight difference in exh port location and cams comes in brown top( vaccum advanced {esiest swap} and black top electronic advance{lots of wiring})
HASport has mount kits wirting conversions and axels for the b series swap must use cable tranny an 84 1.3 VSS or 85-87 hf vss also eith a b16a1 Intake manifold or skunk2 manifold
need more info on these swaps???
http://www.redpepperracing.com
Old May 4, 2004 | 12:30 PM
imasianman's Avatar
Default Re: swaps for 85 crx si (Ghost1)
thanks a lot for the replies!
I want to drop a b series in it but that's not gonna be for a while. The motor still runs great with an unusually low 180k miles.
gonna do my homework on the swap first so there'll be less problems later
thanks again
Old May 4, 2004 | 02:32 PM
99civsi's Avatar
Check this link out, it has the honda swap guide on a free download, full swaps and are in a good price range http://www.totaljdm.com/?id=36226
massh22gsr
Jan 28, 2008 05:28 PM
AWDspyder
Jun 26, 2005 07:56 PM
kck6894
22
Nov 15, 2003 03:11 PM
91 crx Si
Jun 16, 2003 03:15 PM
oneoldcrx
Mar 25, 2003 07:58 PM
