How would i modifiy a 90 civic hatch?
How would i modifiy a 90 civic hatch into a b16a. this car is 1.5 (2 fuel injectors) how would i convert it to be four injectors on the fuel rail and would it just drop in or need new mounts?
You have to do a dual point fuel injection (2 injectors) to a multi point fuel injection (4 injectors) conversion. You will need to buy aftermarket mounts and new shift linkage. Use the search function there are lots of posts about DPFI-MPFI converting. Hope this helps
you need to search the archived threads. there is tons of info there. Look especially in the hybrid forum.
Besides the injector and mounts you need alot more. Wiring (harness and ECU)
Linkage, and axles
Linkage, and axles
