Need Help for Spraying
Hey Ima be sprayin my CRX interior I already got the paint but i feel like im missin a step...im startin with the center console so should i shave it down first then paint or...what... need a lil help thanx
well hopefully you have the right paint to use. But yes you will need to "prep" the panels you're painting. Usually with a little light grit sandpaper and use some solvent to clean the plastic. DO NOT USE any solvent that might eat up the plastic though!!! Also depending on the paint it might need special primer
deeb_xiong
Paint and Body
Mar 20, 2011 02:44 PM
