Clutch Pedal Feels Odd. HELP!
Old May 3, 2004 | 04:53 AM
GreenMachineRex's Avatar
Default Clutch Pedal Feels Odd. HELP!
I got a new clutch probably 1000 miles or so. nothing speical just exedy. But i just started notcing my clutch pedal feeling different. It doesn't push and come up smooth, its almost like there is 3 stages to it going in and out....but doesn't always do this. i was thinking mayeb the cable is going bad....can anyone help/relate. thanks!!!!
Old May 3, 2004 | 04:55 AM
Lo-Buck EF's Avatar
Default Re: Clutch Pedal Feels Odd. HELP! (GreenMachineRex)
make sure your floor mat isnt obstructing the movement of the pedal or cable. (happens to me all the time)
adjust the cable and see if that feels any better. if not, lube the cable.
Old May 3, 2004 | 05:03 AM
Default Re: Clutch Pedal Feels Odd. HELP! (Lo-Buck EF)
i was thinking of taking the pedal cover thigns off...after market ones...c if that helps, but i think i should lube the cable first and then maybe c if that fixes it. hopefully its just that and not the cable going up
Old May 3, 2004 | 05:13 PM
EL Vap133's Avatar
Has the pedal gotten stiffer?
Old May 4, 2004 | 05:59 AM
p1driftfiend's Avatar
Default Re: Clutch Pedal Feels Odd. HELP! (EL Vap133)
My clutch pedal begins to feel wierd after driving for more than 20 minutes and using the clutch alot. It gets very notchy and gets much stiffer at the point closest to the floor. If I puch the clutch very very very slow, it sticks at a point, and I need to exert more pressure to push it down more. If I just use regular force and quickly puch it in, there's no real difference, except I can slightly feel and hear it being more notchy. Anyone no what may be causing this?
Old May 4, 2004 | 06:22 AM
Rollo Lawson's Avatar
it can be a few different things, but, i can tell you one thing, that is, i have an exedy stage 1 and it is ****. everytime i beat on my b16, it feels softer. from my own personal experience with OEM, ACT, CM & exedy(basically oem), the exedy one was the last of the bunch. i know this doesn't help, but, at least you know not to buy or reccomend exedy stage 1 clutches.
Ricextacy
Jan 18, 2012 09:12 AM
Radim
Feb 19, 2010 11:15 AM
InJ3cted
May 24, 2005 02:16 PM
See Are X
Apr 25, 2002 05:04 PM
