NEED A D16Y8 motor wiring diagram ASAP!!!
Old May 2, 2004 | 09:12 PM
Dc_Ek's Avatar
Default NEED A D16Y8 motor wiring diagram ASAP!!!
I'm having problems with the motor on my car (JDM B16 SIR II) and I need to find the motor wiring diagrams to check whether all the sensor are connected correctly, any help would be really aprecciated!
Old May 4, 2004 | 04:25 AM
Dc_Ek's Avatar
Default Re: NEED A D16Y8 motor wiring diagram ASAP!!! (Dc_Ek)
I was able to fix the TPS, KNOCK, but I couldn't find what's wrong with my MAP sensor! THe computer throws a code 5 and I changed the TB gasket, the MAP O-ring, and I even exchanged MAP's with my other car (Integra) but it remains the same!
Any other ideas????
Old May 4, 2004 | 05:45 AM
tgreaves's Avatar
Trace the map sensor wire back to the ecu.. Get a pinout diagram for your ecu and make sure the wire isnt broken anyway..
What did you do to your car to make it throw all those codes.. Did you swap motors or do something with the harnesses..
Old Nov 9, 2014 | 10:26 AM
Si-slam's Avatar
I have the same problem.. Do u know where to get a diagram of the wires that go to map senor? I have a y8 engine harness and the map senor was cut idunno which wires go where. Any help?
Old Nov 9, 2014 | 01:20 PM
HondaPartsHero's Avatar
Technical Hero
List year make and model
Old Nov 10, 2014 | 09:18 AM
Si-slam's Avatar
The harness is a d16y8 going onto 2000 civic si with b16a sir swap.. Map senor was cut so i dont know which color goes where.. Car stays on high rmp when turned on any help?
Old Nov 10, 2014 | 11:33 AM
Technical Hero
https://honda-tech.com/honda-civic-d...guide-3146770/
xxstuntin4life
Nov 21, 2009 06:16 PM
TopEndTuner
Engine Management and Tuning
Oct 4, 2008 04:58 PM
SoOHiGH
May 26, 2005 12:46 AM
