o2 sensor wires cut..please help
my friend has a 92 dx and he accidently cut the wires on his o2 sensor when he was tryin to get it out. what i want to know now is can he reuse the o2 sensor with the wires connected with butt connectors. Or will he need a new 02 sensor. Bassically will cut wires on the o2 sensor mess up the sensor.
so it worked fine when you reconnected the wires, cuz when he reconnected the wires it threw a check engine light and the car was running really rich, so i know that something will wrong but i know that the wires where connected property andhe never touch the sensor with his hands
it will work. Just make sure that you reconnect the wires correctly. I also had to extend my O2 wires for a DC header...
It will work fine if you reconnect the wires.. make sure you connect them correctly.. If you aren't extending them you shouldnt have a problem since you just match up the colors..
The butt connectors could be a problem, Im guessing you didnt crimp them right? The ecu works on low voltage signals so the butt connector could be affecting your connection and throwing off the readings...
When i extended my O2 sensor wires I used sheilded wire for the signal wire and I soldered the connections.. Try soldering the connections and see if it fixes the problem
icefirezero
Jun 6, 2004 06:34 AM
