the 200whp test... can it be done?
Old May 2, 2004 | 08:05 PM
Combustion Contraption's Avatar
Default the 200whp test... can it be done?
Just wanted to start this thread off by saying ive learned a TON of **** from Honda-tech over the past year and half, built my first motor myself, installed it myself (with some help from a few friends) and its running beautifully. During my time here, ive seen ALOT of bullshit posted that everyone takes as the gospel. Compression this, cams too big/small this, that header sucks, bigger throttle body, yada yada. So i decided set a goal for myself that alot of "experts" have said couldnt be done, and achieve it. Im looking for 200 whp on an LS/Vtec w/ stock LS bore, no milling of the head, and....OEM CAMS....
Heres the setup
b18a1 block
USDM ITR Pistons
AEM CAI
Skunk2 Intake Manifold
b18c1 head - unmilled- no port- no polish
CTR Cams
RC eng. 310cc injectors
ericks racing FPR
Walbro 255 lph
VAFC
Tuning will be done by Shawn at church automotive testing, im pretty sure most of you are familiar with him. The only thing im probably going to change before the dyno is the header, some other 4-1 thats not horribly dented on the bottom will probably make more power.
Well, let me know what you guys think!
Old May 2, 2004 | 08:13 PM
Integra4Life89's Avatar
Default Re: the 200whp test... can it be done? (LsVtec92Hatch)
Wish I knew more about engines sorry....
Old May 2, 2004 | 08:45 PM
EKhatch's Avatar
It will be close.
Hondata or the like along with a mild port and polish along with a killer valve job and you could make a more solid run and the mark you have set for yourself.
Old May 2, 2004 | 08:47 PM
SkRiBLaH's Avatar
you wont bust 200, but it should be a kick *** setup!
Old May 2, 2004 | 08:57 PM
EKhatch's Avatar
Default Re: the 200whp test... can it be done? (SkRiBLaH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkRiBLaH &raquo;</TD></TR><TR><TD CLASS="quote">you wont bust 200</TD></TR></TABLE>
You know this for a fact, please enlighten me on how........
Old May 2, 2004 | 09:26 PM
justBLZE's Avatar
Chopper 2 Hopper
Default Re: the 200whp test... can it be done? (EKhatch)
I can't tell if you'll reach 200 but sure wanna know what it will do.. post the results
Old May 2, 2004 | 09:27 PM
riceball777's Avatar
no where near 200 whp
that setup is basically an itr with bolt ons and 11.0 cr. the crank will bump cr .2 and the gsr head will bump it another .2 making 11.0
so an itr make about 165 whp
+.4 cr = 4 hp
bolt ons 5-10 hp
tuning 5hp
i say that set up will make about 170-180whp
theres no way in hell thats going to make 200 whp. the motor is not even built. no porting no big cams cr is not really that high.
like i said that motor is bacically an itr with .4 more compression
your much better off with some pr3 pistons
Old May 2, 2004 | 09:29 PM
gritsak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKhatch &raquo;</TD></TR><TR><TD CLASS="quote">
You know this for a fact, please enlighten me on how........</TD></TR></TABLE>
its alot easier to be short of 200whp then it is to reach it.....i just think guy was sayin his opinion...do you think this setup will break 200? if so please enlighten me cause i dont see it happening either
Old May 2, 2004 | 09:41 PM
EKhatch's Avatar
Default Re: the 200whp test... can it be done? (gritsak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gritsak &raquo;</TD></TR><TR><TD CLASS="quote">
its alot easier to be short of 200whp then it is to reach it.....i just think guy was sayin his opinion...do you think this setup will break 200? if so please enlighten me cause i dont see it happening either</TD></TR></TABLE>
I already made my reply as you can see if you read the post.
I would post my success stories leading me to believe that it is capable but 90% you guys wouldn't believe it anyway so I am not going to waste my time.
Old May 2, 2004 | 09:43 PM
dfoxengr's Avatar
https://honda-tech.com/zerothread?id=746126 check it out
Old May 2, 2004 | 09:48 PM
EKhatch's Avatar
Default Re: the 200whp test... can it be done? (hybridvteceg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=746126 check it out </TD></TR></TABLE>
Haha........ummm IB4TL???
Old May 2, 2004 | 10:06 PM
Ti3d in's Avatar
I like these kind of projects
200whp es posible Better have a damn good tuner
Old May 2, 2004 | 10:18 PM
HondaGuy02's Avatar
Banned
Default Re: the 200whp test... can it be done? (Ti3d in)
im almost positive even tuned that set up wouldnt reach 200whp.
i would think with out head work, it couldnt be done. I might be wrong though.
Old May 2, 2004 | 11:39 PM
JDM KING's Avatar
I had a ls-vtec with jdm itr pistons with gsr head no pnp no mill with itr cams and skunk2 brain that made a whopping 193 to the wheels...just with 4into1 jdm headers and a vafc...that was pretty amazing considering it was pretty much a shitty set-up...but good luck on ur goals!
Old May 2, 2004 | 11:43 PM
i dont think this thread should be locked. its not a guess my hp thread. Its about a project and a goal that i have set for myself and im going to keep you all informed.
Ill post what works and what doesnt, i think people could wind up learning alot from this thread. "Guess my HP wasnt my intention" Mods PM me if you feel i am wrong.
Old May 3, 2004 | 05:07 AM
Lip's Avatar
Lip
Default Re: (LsVtec92Hatch)
its still a guessing post. does it matter if it makes 200whp? All that matters is its strong, great running, reliable and makes you happy in whatever venue you use it for. its still a post to see if your at a 200whp mark. i know how you can find out? a dyno machine
Lozano1991
May 24, 2013 07:56 PM
Mr. EK9
Mar 9, 2011 03:24 PM
94WhtTeg
19
Jul 23, 2008 04:00 AM
playa-ej1
19
Jul 23, 2007 11:08 PM
boosted k20
10
Jul 29, 2005 11:00 AM
