Transmission Question?
Old May 2, 2004 | 07:54 PM
The G2 Racer's Avatar
Default Transmission Question?
How hard is it to swap the guts of a tranny into another casing?
Why one case is cracked but the rest of the tranny is fine so I'm going to swap the gears into the new case myself if it's not too hard.
BauleyCivic's Avatar
Risky Business
Default Re: Transmission Question? (The G2 Racer)
D-series or B-series?
Old May 2, 2004 | 08:03 PM
Default Re: Transmission Question? (BauleyCivic)
B series.
B16 hydro tranny to be exact.
Old May 2, 2004 | 08:06 PM
IS3Fifty's Avatar
Do you have any tranny experience??? your talking about an involved process.
Ricey has a tranny removal DIY post on here somewhere, do a search for creator "Ricey McRicerton". It should help a little, at least with dropping the tranny. As for the gear swaps, can you afford a new tranny?
Old May 2, 2004 | 08:11 PM
Default Re: Transmission Question? (TODAeg6)
I can't afford a new tranny. Hence swapping the guts.
What would I shop charge me to do this?
Old May 2, 2004 | 08:12 PM
Ricey McRicerton's Avatar
My tranny removal thread
https://honda-tech.com/zerothread?id=811691
Bauleys tranny removal thread
https://honda-tech.com/zerothread?id=596873
Plan B's Tranny dissasembly thread
https://honda-tech.com/zerothread?id=722416
If you have any specific questions feel free to me.
As long as you're swapping stuff from one identical tranny to the other it's really not too bad.
Old May 2, 2004 | 08:21 PM
Default Re: Transmission Question? (Ricey McRicerton)
Thanks for the links Ricey!
Thankfully the tranny isn't in the car so that'll make it easier.
I've got no exp. with trannys. Can I screw it up and mess up my tranny?
Old May 2, 2004 | 08:26 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The G2 Racer &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the links Ricey!
I've got no exp. with trannys. Can I screw it up and mess up my tranny?</TD></TR></TABLE>
Honestly, yes. Make sure before you put it back on the car it will shift into every gear and you're not locked out of any of them.
If you don't have a Helms manual I suggest you get one first.
Also, take pictures of stuff and do your best to remember how it looks before you tear it down. It's honestly not that tough, but just make sure you keep evetything organized when you do it.
Old May 2, 2004 | 08:45 PM
Thanks for all the info.
I may or may not do it myself. I'm going to call a few tranny shops tomorrow and see what prices they give me.
Old May 2, 2004 | 08:51 PM
Evs-One's Avatar
Solbros Owns Me
transmissions are very simple.
A Helms will help guide you through it....it's too hard to explain everything with text. If you can turn a wrench and use a feeler gauge, you're good to go
turboef90
Transmission & Drivetrain
May 5, 2013 12:19 PM
Fatcobra
Mar 27, 2009 05:14 AM
OMG WTF
Jan 28, 2006 08:04 PM
