Clutch Problems, I searched! NEED HELP ASAP!
I lost all pressure to the pedal, it comes back up, but there is no pressure behind it... it is not engaging and I cant put the car in gear, but lost no fluid... no fluid squirts when the pedal is pushed down... no fluid loss... ANY IDEAS?
I searched and everything i found said that the clutch either stuck to the floor (which myne didnt do) or lost a **** load of fluid (which it also didnt do)
bleed your cluctch again. see if it is the same... if the same your clutch m/c may have an iternal leak if you dont have any leaks under the car..... junk yard sells them for about 10.00 bucks...
