Compression Test Results: ...i'm gonna guess this is bad.
Old May 2, 2004 | 06:55 PM
Civic Hx-T's Avatar
Default Compression Test Results: ...i'm gonna guess this is bad.
D16z6 bought off of someone--
165 170 160 165...
Put a little oil in three of the pistons... all three shot up to 180 190 180.
My car starts... get on the gas it studders and bogs, then dies.
Is this the reason my freaking car won't drive out of the driveway?
Old May 2, 2004 | 08:35 PM
NonovUrbizniz's Avatar
Loved
Default Re: Compression Test Results: ...i'm gonna guess this is bad. (Civic Hx-T)
when's the last time it ran... what have you done to it since...
Those numbers aren't horrible... if you did it after the engine had sat a long time it may have not made good compression without oil on the cyl. walls...
I'd do a leak down test to be sure that oil isn't getting by the rings... but those numbers aren't bad if it was dry... they're not great though.
From what you described I'm gunna guess you put the wires on in the wrong firing order...
But that going on no other info than you did a compression test then the car doesn't run right.
Old May 2, 2004 | 08:40 PM
Civic Hx-T's Avatar
Read my other thread. It's still on the first page..
"Neverender.. car doesn't run right yada yada"
That'll tell you everything. Thanks man.
Old May 2, 2004 | 08:47 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: (Civic Hx-T)
nuymbers look great.
put oil in any engine and do a test and they will go up.
Old May 2, 2004 | 08:49 PM
Ricey McRicerton's Avatar
Default Re: (Emerika)
I agree with Emerika. As long as they're all withtin 10% or so of each other things are looking good.
Old May 2, 2004 | 08:58 PM
Civic Hx-T's Avatar
Well thanks for the info.
I dont think im going to waste my money rebuilding anything.
But this sucks. I can't figure out why my car won't drive right.
Old May 2, 2004 | 09:00 PM
Any CELs?
Checked your timing? Done a basic tuneup (fuel filter, air filter, plugs, wires ,etc...)
Old May 2, 2004 | 09:02 PM
Civic Hx-T's Avatar
https://honda-tech.com/zerothread?id=849500
read and comment. That's everything I did so far.
Old May 2, 2004 | 09:07 PM
SOHCEK-Turbo's Avatar
Those Compression numbers are good it has to be something else a sensor or something. I have 150 across at the moment and car runs ok. Will be replacing it soon dough.
Type 56
Oct 12, 2016 11:10 AM
Junkie
Mar 22, 2008 12:21 PM
climb_on
Jul 29, 2007 03:40 PM
Azcheron
Jun 23, 2005 09:34 PM
Andrew 825SM
Oct 19, 2002 10:05 PM
