DSM 450 injectors (resistor question)
Old May 2, 2004 | 06:36 PM
94B18B1Teg's Avatar
Default DSM 450 injectors (resistor question)
I understand that the DSM's are peak and hold, while our motors are set up for saturated. What I don't understand is the difference between those 2. Also, I understand I should get...4 10watt 10ohm resistors to run in place of the power wires that go to the injectors to regulate the voltage and whatnot. Its just that I don't want to get this on there, and not know why I need it, or why it doesn't work, or why my engine bay has to look real ghetto with electrical taped resistors running to the injectors. It just sounds kind of un-reliable, can someone help me out? thanks.
Old May 2, 2004 | 07:13 PM
94B18B1Teg's Avatar
Default Re: DSM 450 injectors (94B18B1Teg)
bump
Old May 2, 2004 | 07:21 PM
powerofdreams8's Avatar
get you a resistor pack and it will look much nicer i've got a few laying around if you want one, 25 bucks shipped
pm me
Old May 2, 2004 | 08:11 PM
94B18B1Teg's Avatar
Default Re: DSM 450 injectors (powerofdreams8)
I may be interested, but can you answer the other questions I've asked about the resistors in general? thanks.
Old May 2, 2004 | 08:15 PM
SOHC_MShue's Avatar
i got the resistor box and it looks clean!
Old May 2, 2004 | 08:37 PM
the.hamburglar's Avatar
Default Re: DSM 450 injectors (SOHC_MShue)
yes i would like to know as well
Old May 3, 2004 | 12:03 AM
jdm91integ's Avatar
https://honda-tech.com/zerothread?id=704760
Old May 3, 2004 | 04:50 AM
notoriousB's Avatar
you can solder in the 10w 10 ohm resistors in line with each yellow/black wire to the resistor, if you do it right you can get them to tuck right back in with the stock injector wiring, and you can't even see them. I was even able to get the plastic wire "trim" back around all the wiring, can't even tell the resistors are there.
Old Nov 9, 2004 | 06:43 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: (notoriousB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notoriousB &raquo;</TD></TR><TR><TD CLASS="quote">I was even able to get the plastic wire "trim" back around all the wiring, can't even tell the resistors are there.</TD></TR></TABLE>
can you get a pic of that? im going turbo on my 92 and im going to have to do this resistor trick..
Old Nov 9, 2004 | 07:06 PM
EJ1 wilcox's Avatar
Default Re: (Built B16A)
Just solder the resistors in, seal them with some shrink wrap, then wrap them up in that black plastic fire-proof stuff (can't remember what it's called)...
then tuck them back behind the fuel rail and you can't even see them
Old Nov 10, 2004 | 02:27 AM
T-RO's Avatar
Solderless resistor box install
https://honda-tech.com/zerothread?id=736737
jdmboy94
Oct 13, 2010 02:43 PM
Vtec92Civic
Aug 18, 2005 10:58 PM
NOTENOUGHBOOST
Feb 15, 2004 09:23 AM
FBP Si 2000
Dec 14, 2003 10:56 PM
sivik2nr
Jun 11, 2003 09:59 PM
