Definition of Spun
Old May 2, 2004 | 06:23 PM
Supra's Avatar
Default Definition of Spun
I've heard the term "spun" tossed around a lot. Right now I know that it is a bad thing to spin something. Can someone enlighten me to exactly what this means?
Old May 2, 2004 | 06:37 PM
Wes V's Avatar
Default Re: Definition of Spun (Supra)
It's pretty much what it sounds like. It normally refers to when you spin a bearing (rod or crank).
If you can get your hands on a bearing, you will notice that there is a small "tang" (I don't know of any other name for it) that when installed prevents the bearing shell from rotating.
In addition to the tang, there is a clamping force on the pair of bearing half shells that also prevents them from rotating within the block.
In a perfect world, the crankshaft doesn't really come in contact with the bearing surface, but floats on a thin film of oil. If oil pressure drops, then this film is lost and there is contact between the two. The resulting frictions welds the bearing to the crankshaft and then "spins" within the block. This is BAD news!
Wes Vann
SurferDude905
Jun 29, 2009 04:30 AM
xxmastermindxx
May 6, 2007 09:17 AM
i-VTEC_do_you
Jul 19, 2006 09:44 PM
turbociv
15
Mar 11, 2004 01:16 PM
jdmcivicferio
Mar 16, 2003 06:54 AM
