Toda cam gears, you guys shoudl read if you want the best...
Old Nov 2, 2001 | 06:58 PM
Mr.Integra's Avatar
Default Toda cam gears, you guys shoudl read if you want the best...
i just took these cam gears out of my integra gsr today and then i compared them to stock cam gears. EVERY SINGLE TEETH MATCHES UP PERFECTLY. AEM/Skunk2 cam gears are off from stock slighty, but toda cam gears matches up PERFECTLY. Just an FYi. so for those of you who wants perfect tuning, these cam gears are a must for you.
Old Nov 2, 2001 | 08:24 PM
RStoR's Avatar
Default Re: Toda cam gears, you guys shoudl read if you want the best... (Mr.Integra)
Are you referring to the older version or newer version?
I assume your aware that the older Toda's, Spoon, JUN, and HKS (I believe) all actually use the Honda OE gear and tap it for an adjustable plate. Everything would line up correctly because they are the same unit. Good observation!
Old Nov 3, 2001 | 07:49 PM
Mr.Integra's Avatar
Default Re: Toda cam gears, you guys shoudl read if you want the best... (RStoR)
thx i was referring to the new version.. these cam gears rock!
Old Nov 3, 2001 | 09:03 PM
leechungsr's Avatar
Mr. Integra ran 14.00 with those cam gears.. they must be good.
ek4serge
Dec 31, 2011 08:18 PM
brandonschmidt
12
Dec 5, 2009 01:11 PM
Chris N
Dec 30, 2002 09:58 PM
macdaddy
Apr 15, 2002 08:17 AM
IntegraGSR23
Jan 27, 2002 04:34 PM
