Type R intake fit in an LS?
Old May 2, 2004 | 02:49 PM
3 plus 1's Avatar
Default Type R intake fit in an LS?
Will an aftermarket Type R intake fit in an LS?
Old May 2, 2004 | 02:53 PM
cougar10ag's Avatar
i'm pretty sure it'll work. depends on the intake tho.. the TB's line up. short rams will work. the CAI might not as it may be made for the more compact ITR ABS system
Old May 2, 2004 | 03:33 PM
stumpyf4's Avatar
Default Re: Type R intake fit in an LS? (3 plus 1)
My buddy has a ITR AEM CAI on his GS... you have to chinch down the silicone coupler on to the GS throttle body. There are a couple areas where theCAI is tight... tight to the sparkplug wires on the distributor and it tight where it's vertical near the front, rubs somewhat on the A/C lines.
Old May 2, 2004 | 03:37 PM
3 plus 1's Avatar
If its rubbing that exactly what I dont want. Reason for getting rid of my short ram is its rubbing all the rubber off my AC lines. I want to replace it with an intake that has a bracket to prevent it from doing that.
Old May 2, 2004 | 03:43 PM
W.O.P.'s Avatar
Default Re: (3 plus 1)
why? you will get no extra gain
Old May 2, 2004 | 03:49 PM
982drLS's Avatar
take your a/c system out.. unless u absolutely need it
Old May 2, 2004 | 03:55 PM
slim9300's Avatar
Default Re: (982drLS)
Shouldn't rub on anything. The AEM CAI (3'' Integra Type-R) comes with a mount that keeps the intake solid, it located right behind the coolant over flow bottle. I will sell you mine in the first week of June.
94WhtTeg
Oct 28, 2007 08:08 PM
j954drgsr
Jun 24, 2005 08:20 AM
hallsy
Apr 19, 2004 12:15 PM
JLange
Jan 20, 2003 04:25 AM
millertime
Sep 11, 2001 06:51 PM
