Suspension tips/advice needed on ‘04 Accord Coupe 6 speed
Just upgraded '00 LX sedan to '04 EX 6 Speed. Yes, it's fast a little to fast.
The suspension in this car is good, but not enough.
There is too much play (loose) and bouncing going around turns at higher rates of speeds. I have read some previous post regarding suspension, but I need to know if anyone has upgraded the suspension for this model accord. I prefer tight handling. There is so much power when shifting, the car shifts. If so, what did you use and can recommend.
Modified by lotsill at 8:16 PM 5/2/2004
Modified by lotsill at 8:17 PM 5/2/2004
ummm...the TL's and the 6 speed accords are the exact same. The suspension set up on the 6 speed accord is the EXACT same as that of the newest TL.
the tl does not have the exact same suspension of a 6 speed. i have a 03 6 speed and i suggest you get a rear tl sway bar. that helps alot and gets rid of alot of the bouncy feel and stiffens it up all around. 2nd your gonna hafta get springs or coilovers. i have the s-tech springs which made a hugeee difference.
overall you need that new rear sway, and can add springs maybe a front sway.
gustavito1986
Nov 28, 2008 09:59 PM
George Knighton
Jan 13, 2006 07:26 PM
First Honda 1976
Apr 13, 2004 11:31 AM
