Koni Adjustments.
Hi,
I have just bought a set of Koni Yellow Sport Shocks for my car.
They are still not fitted yet......
I was seeing how you adjust the damping......
If i turn the **** towards full stiff (firm) should it stop turning somewhere or not please?
It seems it continues to turn...................
Regards,
Regards,
Dutchitr1689, just told me that the **** isn't stopping cause since the shocks aren't yet mounted the rod is turning with the ****..........
So now i have an other problem guys......
Do you think that by doing so i umscrewed something in the shock then please?
Rgds,
Rgds,
u should be fine, just wait till u install them then adjust them.
they will stop when u turn it all the way in 1 direction.
also if u turn it to full stiff, i heard it's better for the shock if u turn it back just a tiny bit so it's not all the way turned to full stiff...
Thanks for the reply.
So, you don't think that i screwed something up.......
I am a little bit paranoid....i don't want to install these shocks knowing that one of them is unscrewed or something.
But it seems that the rod rotates freely with the ****....
rgds,
rgds,
poormanstyperb16
Suspension & Brakes
14
Oct 28, 2010 12:56 PM
Install the shocks, they'll be fine, you can't f-em up that easily.
