weird creakin noice from rear..
Old May 1, 2004 | 09:20 PM
TRF #001's Avatar
Default weird creakin noice from rear..
iight this might sound dumb but i dunno, my 99 civic Si lowered wit skunk 2 coilovers and ingalls camber kits all around... the back of the car creaks real bad over big bumps, un-even roads, or even when the car is just shifting weight (corners) i never really noticed before but now i got my back seat out cause im about to get a cage put it. i checked strut bushings, all the bolts, and greased all the camber parts and so on. i can figure out what the hell is creaking, any info or advice would be great. thanx (oh and if it matters, i had a rear strut bar on before, but took it off for the cage install)
Old May 1, 2004 | 09:21 PM
Ziatic's Avatar
could it be blown shocks? thats what im thinking
Old May 1, 2004 | 09:24 PM
TRF #001's Avatar
Default Re: weird creakin noice from rear.. (Sleepin Si)
i looked at the shocks, but didnt see any **** leakin or anything like that, it was a thought of mine too tho, thanx for ur input
Old May 1, 2004 | 09:26 PM
Sliced Beard's Avatar
your camber kit uses urethane bushings
urethane is notorious for creaking when it is rubbing against something
Old May 1, 2004 | 09:28 PM
ABK's Avatar
ABK
Default Re: weird creakin noice from rear.. (dirtyd463)
Yep utherane creaks like a bitch, but I like it.
Old May 1, 2004 | 09:29 PM
TRF #001's Avatar
good lookin out, i'll look into that tomorrow, anything i can do about it?
Old May 1, 2004 | 09:36 PM
ABK's Avatar
ABK
not really unless you find some rubber bushings to put in there. **** if you want a nice handeling suspension I would suggest to replace all your bushings with utherane ones. They make the car handle alot better!!!
Old May 1, 2004 | 09:51 PM
JforJonathan's Avatar
Default Re: weird creakin noice from rear.. (ABK)
damn i have this same EXACT problem on my 00 si. its lowered on skunk 2 coilovers too. i have no camber kit, and i still get the creaking noise. i dont think it has to do with the bushing to tell you the truth. did it make this noise with teh rear strut bar?
Old May 1, 2004 | 10:11 PM
99blackcivicSi's Avatar
Default Re: weird creakin noice from rear.. (Dj Villain)
Check the endlink on the sway bar
Mine came loose on my 99 Si for some wierd reason after i lowered it don't knwo why but tightened it and no prob.
Old May 1, 2004 | 10:18 PM
Default Re: weird creakin noice from rear.. (99blackcivicSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blackcivicSi &raquo;</TD></TR><TR><TD CLASS="quote">Check the endlink on the sway bar
Mine came loose on my 99 Si for some wierd reason after i lowered it don't knwo why but tightened it and no prob. </TD></TR></TABLE>
my endlinks are good cause i just put on my SRR lca's
Old May 2, 2004 | 07:06 AM
TRF #001's Avatar
nah, i never noticed it before when i had the strut bar, i swear its like the whole body twisting or sumpthin, lol, but yea i'll check into the end links and stuff, thanx guys, greatly appreciated
Old May 2, 2004 | 10:44 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepin Si &raquo;</TD></TR><TR><TD CLASS="quote">nah, i never noticed it before when i had the strut bar, i swear its like the whole body twisting or sumpthin, lol, but yea i'll check into the end links and stuff, thanx guys, greatly appreciated</TD></TR></TABLE>
i think its the body twisting too...but i cant figure out what to do to fix it. i think i might get a rear strut bar, since you said you never noticed it when you had the strut bar. i know exactly what you're talking about cause mine did it ever since i lowered it
Old May 2, 2004 | 11:25 AM
hatchdrvr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepin Si &raquo;</TD></TR><TR><TD CLASS="quote">the back of the car creaks real bad over big bumps, un-even roads, or even when the car is just shifting weight (corners) </TD></TR></TABLE>
join the club.....my hatch sounds like I've got a mouse orgy going on in the back.
Old May 2, 2004 | 11:36 AM
-auSTIn-'s Avatar
Default Re: weird creakin noice from rear.. (hatchdrvr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchdrvr &raquo;</TD></TR><TR><TD CLASS="quote">
join the club.....my hatch sounds like I've got a mouse orgy going on in the back.</TD></TR></TABLE>
Hahaha me too...I have rear strut as well, still makes noise and I have checked everything before. If anyone could pinpoint the problem that would be great but I guess for now I will just continue to tune it out, or turn up my music
Old May 2, 2004 | 12:30 PM
Default Re: weird creakin noice from rear.. (B18C5_EK)
damn seems like many people have this problem. i wanna know what it is cause its really annoying and makes my car seem crappy
deeksmooth's Avatar
i have the ingall's rear kit too... creaks like crazy, if you figure out a fix for it, lemme know.
Old May 2, 2004 | 12:36 PM
5w20's Avatar
Default Re: weird creakin noice from rear.. (citrEK)
did anyone check the rear trailing arm bushings?
Modified by 5w20 at 4:01 PM 5/2/2004
Old May 2, 2004 | 12:41 PM
aphex23's Avatar
Default Re: weird creakin noice from rear.. (5w20)
i would like to chime in and say i have a problem as well, i have stock suspension though, and it just started, i would classify it as a squeek rather than a creek...? it is damn annoying, come from the rear section, dunno what the hell it is!
any thoughts?
Old May 2, 2004 | 01:00 PM
5w20's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5w20 &raquo;</TD></TR><TR><TD CLASS="quote">did anyone check the rear trailing arm bushings?</TD></TR></TABLE>
Old May 2, 2004 | 01:05 PM
rickske's Avatar
LOL! Same **** over here w/ my EG, but mine sounds more like the TITANIC sinking.......
Old May 2, 2004 | 02:07 PM
travizx0r's Avatar
i have the same problem with my 99 si. all the suspension is stock and any bumps or anything will make a creek/sweek noise from the rear. its been driving me crazy i wish i could figure out what it is
Old May 2, 2004 | 02:43 PM
Modified by 5w20 at 4:01 PM 5/2/2004</TD></TR></TABLE>
how do i know if they are good or bad? ive looked at them, they look kinda messed up, like theres pieces missing out of it.
Old May 2, 2004 | 03:39 PM
TRF #001's Avatar
wow guys, didnt exspect this much feed back, lol, i thought i was the only one that had fucked up suspension, haha, if anyone can find a cure for the creaking squeeking we all got goin on here it would be greatly appreciated... ima throw my car on the lift tomorrow and go over everything possible, i'll post up and let you all kno what i find....thanx again
Old May 2, 2004 | 04:06 PM
5w20's Avatar
If they have cracks in the rubber replace them. After awhile the rubber can "crack" (break) all the way through over time since it is rubber.
http://www.hondaautomotivepart...R+ARM
For those of you who dont know what it looks like its on the biggest arm by the #30 bolt. It is right above it. They usually tear on the part that faces the wheels not the part that faces inward. It cracks (or in some cases breaks) on the lower half portion.
Modified by 5w20 at 7:57 PM 5/2/2004
Old May 13, 2004 | 05:16 PM
TRF #001's Avatar
guys, i found the problem to the creek,squeek, or watever u wanna call it. i had my brother lay in the trunkof my car when i drove to pinpoint the problem. its the brace that connects the rear seatbelt mount to the strut mounting point, when the car flexes it makes that noise. we took off the bracket and the noice went away, so what we did was stick 2 pieces of dynomat inbetween the bracket and the mount and tightened the bolt and the noise was gone. well i hope i helped all of you guys out that have this problem, bad honda design i guess, but i still love em, lol
