climate control doesn't light up!
Old May 1, 2004 | 07:23 PM
ieatrice's Avatar
Default climate control doesn't light up!
my climate control works fine, but it doesn't light up like it's suppose to at night. i replaced the bulbs and they still don't work. what could be wrong?
Old May 1, 2004 | 08:27 PM
SkRiBLaH's Avatar
Default Re: climate control doesn't light up! (ieatrice)
boo ******* hoo.. please go away.
Old May 1, 2004 | 08:34 PM
Ricey McRicerton's Avatar
Default Re: climate control doesn't light up! (SkRiBLaH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkRiBLaH &raquo;</TD></TR><TR><TD CLASS="quote">boo ******* hoo.. please go away.</TD></TR></TABLE>
Uncalled for...watch it.
And what do you mean doesn't light up like it's supossed to? Does it light up at all or does one side dim in and out? There are a bunch of members who have one side of the climate control that goes in and out. Mine does it. I've had it all apart and can't figure it out.
Old May 1, 2004 | 08:40 PM
ieatrice's Avatar
Default Re: climate control doesn't light up! (Ricey McRicerton)
well, i was looking at bauley's DIY amber lighting thread and i did my cluster first. it turned out great, so i decided to do my climate control also. i took every the climate control apart and swapped the bulbs. when i plugged everything back up, there is no lighting at all. i thought the bulbs weren't in all the way, so i took it out to make sure. i even put back to the stock bulbs to check and it still doesn't work. there's only 2 connectors to the climate control right? thanks for helping ricey
Old May 1, 2004 | 08:45 PM
yes, there are only 2 plugs. I forgot to screw some of the stuff back in and mine didn't light up one time. Did you get all of the screws back in?
Old May 1, 2004 | 09:38 PM
Donkey85's Avatar
but out the voltmeter and see if your getting power to the bulbs socket. if you arent then you know its a wiring issue not if you are getting power maybe check a grounding issue
Old May 1, 2004 | 09:41 PM
ieatrice's Avatar
thanks for all the help guys
Old May 1, 2004 | 09:44 PM
5thgensedan's Avatar
Default Re: climate control doesn't light up! (Donkey85)
I have the same problem. Unfortunatley my car is still an automatic and the lights around the shifter dont work either. Sometimes when I hit a bump they come on. I kinda like it better when they're off though. If I puch the dash right above the climate controls one side comes on, . Same thing happens with the shifter lights too. I'm too lazy to fix it, and furthermore I just don't care. I think it adds character too
Old May 2, 2004 | 08:41 PM
ieatrice's Avatar
tried everything.. still don't work.
Old May 3, 2004 | 03:10 PM
Donkey85's Avatar
did u check to see if ur getting power to the bulb sockets?
Midori Green
Oct 27, 2008 07:24 PM
chai_ek9
Jun 11, 2008 11:03 AM
cutelilvi3tboig
Nov 4, 2004 09:25 PM
clutch33
Mar 23, 2004 06:14 AM
Xymox
Nov 28, 2003 05:04 AM
