doing full motor buildup!! opinions on setup.
Old May 1, 2004 | 06:17 PM
Type RS's Avatar
Default doing full motor buildup!! opinions on setup.
alright i though my motor blew, but it was only a couple of bent valves, but since the motor is already out and i already got the money to build it i'm going ahead w/ it.
here is what i'm doing: weisco/ross/je pistons (11.8:1), eagle rods, darton/aebs sleeves, bored out to 84mm and some ss valves. already have skunk stage II cams and skunk valvesprings and retainers, DTR header.
the car ran strong as hell when i put the header on. i was very impressed and was so upset the valves decided to give out on dyno day. i pulled 176whp before the DTR header and Hytech exhaust (which by the way is quiet as hell) and was hoping on some really good numbers.
now 84mm equates to how many liters? the DTR header is made for a 1.8 motor and i really don't want to wait another month or more if i have to get the 2.0 header.
but either way i'll be happy and i'm hoping on pulling over the 200whp mark. (crossing fingers)
Old May 2, 2004 | 01:27 AM
Toda Built's Avatar
Default Re: doing full motor buildup!! opinions on setup. (Type RS)
What head will be going on this car? any head work done? With proper tuning you sould be in the 200whp range.
Old May 2, 2004 | 08:16 AM
1 2 NV's Avatar
ur staying NA and there is no need for SS valves, thats just bling factor. NA cars do not run enough heat in the motor to warrant SS. id drop some ferrea valves in there with a good valve job and call it a day.
Old May 2, 2004 | 03:02 PM
nickgmiller04's Avatar
84mm=?? depends on what crank youre using.
ls crank 1.9xx liters roughly 2.0 liters
sounds good
Old May 14, 2004 | 04:03 PM
Type RS's Avatar
Default Re: doing full motor buildup!! opinions on setup. (Toda Built)
the head is the stock jdm itr head. no extra pp except for what honda did from the factory.
the crank is gonna be the stock itr crank. at least the guy didn't tell me anything about changing the cranks.
as far as the valves. i have to call the shop and see what kinda valves they are gonna use. he recommended ss though.
Old May 14, 2004 | 07:37 PM
b16vtecsol's Avatar
eagle rods too heavy
Old May 15, 2004 | 12:41 PM
Type RS's Avatar
Default Re: doing full motor buildup!! opinions on setup. (b16vtecsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16vtecsol &raquo;</TD></TR><TR><TD CLASS="quote">eagle rods too heavy </TD></TR></TABLE>
thanks for opinion buddy boy
Old May 15, 2004 | 01:21 PM
B18 CYA's Avatar
eagle rods are not too heavy, i have eagle rods and no complaints. took out my stock rods and boy were the stock rods wayy heavier
ekkilla23
Dec 27, 2009 11:09 PM
tofu-eg
95
Jul 23, 2009 08:57 PM
IntegraType-R
42
Mar 26, 2006 09:05 AM
94DOHCGsr
10
Nov 11, 2005 09:22 AM
DCFIVER
Jan 18, 2005 12:04 PM
