testing waters: built poormans typeR swap
Guest
Posts: n/a
not for imediate sale, engine is still in it's break in period, at time of sale it will have between 3500 and 4000 miles on it. heres the setup:
SiRII five million series head with
-CTR cams
-STR 5 bolt adjustable cam gears
-type r outer valve springs/portflow inners/Ti retainers
-mild exhaust side p&p
-skunk2 manifold
-330cc denso injectors
94 GSR block:
-.028" deck mill
-25 over bore PCT pistons
-eagle rods
-block gaurd
-all new rod/main bearings from acura
-arp head studs
-arp rod bolts
B16 tranny:
-ACT clutch(street disc)
-fidanza 7.5lb flywheel.
basically i would be selling it as a nearly complete sway w/ axles shift linkage p30 ecu, dizzy, alternator, most of the suff you'll ned to start from scratch, if i get alot of people asking for this part and that part i may part it out. posts and PMs only please.
:note, this motor has not been abused, it is going through a very careful break in with oil changes at 200 miles 500 miles 1000 miles and 3000 miles, it won't be "tired". i'll post up compression test results after a few more miles.:
-CTR cams
-skunk2 manifold
94 GSR block:
-.028" deck mill
-eagle rods
-block gaurd
-arp head studs
-arp rod bolts
B16 tranny:
Guest
Posts: n/a
some of it,
New ITR innner valvesprings
http://cgi.ebay.com/ebaymotors...SE:IT
GSR block girdle
Vtec oil jets
GSR/typeR oil pick up and windage tray
GSR oil cooler
GSR block girdle
Vtec oil jets
GSR oil cooler
MassScene
May 23, 2007 12:46 PM
Playero713
Dec 22, 2004 10:21 AM
