Overdrive Pulley Questions (94 Accord)
Hey,
Question for a 94' Accord:
Does anyone know how to get both the Alternator and Power-Steering pulleys off? I'm trying to install light-weight pulleys and I can't get the stock ones off. I messed up the power-steering pulley pretty badly. So right now, I'm driving around with no power steering. Any help would be great.
it helps if you got an air gun. the power steering nut is left hand thread, so to remove it, turn to the right. the alternator is regular right hand so left to remove it.
nope, all you need is a 10mm,12mm, and 14mm sockets to get the alternator off. im not sure shat size the bolt that holds the pulley in is, i think 27mm, its been awhile since i changed the pulley.
ok but how do you hold the larger nut still while trying to loosen the smaller nut? If you put a socket on there, you wont be able to get to the smaller one. And what do I need 3 different sockets for? I thought there was only the larger one (i think a 24) and the smaller one (10 or a 12), so what's the 3rd socket for? Thanks
