Sir II swap into 1996 civic HX.
I'm going to be swapping a obd I JDM b16a Sir II motor into my 1996 OBDII Civic HX.
I searched and couldnt find anything specific for this swap into an hx.
I have both engine harnesses (OBDI and OBDII) and a p30ecu. Which engine harness do I use??? what modifications need to be made???
If I plan to keep ac, what ac bracket from what car do I use???
Which engine mounts do I need from the 99-00 Si???
What axles do I use???
Doesnt the HX have a 5 wire o2 sensor??? would i need a new o2 sensor for the swap???
Thanks for all the help.
