MPFI Distributor Wiring Question
i am trying to change over my d16a6 distributor wiring to my DX distributor plug, the thing is that i dont see any of the colors on the distributor that all the guides talk about (blue green and blue and yellow) Do i have the wrong distributor? the part number is TD-18U
heres a pic of the wires, im in the process of transferring em.
so far i see:
1 blue and yellow
1 blue and green
2 white
1 orange and blue
1 white and blue
1 white and orange(or maybe its just really light orange i cant tell)
total of seven wires. which wires are supposed to go into the plugs?
thanks for the help!
so far i see:
1 blue and yellow
1 blue and green
2 white
1 orange and blue
1 white and blue
You need to clarify what it is you are trying to do.
The only difference is that that DX distributor does not have the blue/green and blue/yellow.
So what do you currently have, what engine do you have, what ECU are you using???
if you are going to use the DX dizzy harness plugs, you will prob have to run blu/grn and blu/yellow wires directly. it doesnt really matter which wire(s) you choose as long as the colors match up.
the si harness plugs are round and i believe can hold more wires.
ohhh okay, i figured it out, i matched up the colors and routed the wires to the ecu. theres one guide out there that told me to switch around all thes wires...which was wrong...thanks for the help guys.
