Went BACK to the track again...(d16y8 sol)
Old May 1, 2004 | 09:54 AM
elevatethis's Avatar
Default Went BACK to the track again...(d16y8 sol)
Practice practice practice and more seat time, I got down to a 16.11 from the 16.4X i ran last weekend. Heres the info on the slip:
r/t - .6526
60 ft - 2.4279
330 - n/a
1/8 ET - 10.3396
1/8 MPH - 67.32
1000 ET - n/a
1000 MPH - n/a
1/4 ET - 16.1158
1/4 MPH - 85.10
comparing that to last week's best:
r/t - .323
60 ft - 2.481
330 - 6.978
1/8 ET - 10.688
1/8 MPH - 66.49
1000 ET - 13.858
1/4 ET - 16.497
1/4 MPH - 85.77
So I guess I just need to keep practicing. If anyone has any tip2 from the numbers above, keep them coming.
Old May 1, 2004 | 10:04 AM
EJ1_519
Guest
Posts: n/a
Default Re: Went BACK to the track again...(d16y8 sol) (elevatethis)
what do you have done to your car?
I'm planning on going to the track tonite so I'm a newbie at drag racing also.
Old May 1, 2004 | 10:09 AM
Default Re: Went BACK to the track again...(d16y8 sol) (EJ1_519)
D16Y8 Del Sol ('97 Si)
I/H/E, FPR, b&m short shifter
kyb struts, coilovers
25 psi in front tires
I think I could pull a 15.9 if I could get my 60 ft down. I had a run last night where I had a 2.37 60 ft, but then I missed 3rd and ran a 16.7 I think that could have been a 15.9 or 16.0 run.....
Old May 1, 2004 | 10:56 AM
Nerologic's Avatar
geeez, i didnt know del sols were that heavy
Old May 1, 2004 | 10:59 AM
Default Re: (Nerologic)
yeah they are....2,400 plus some change without the driver
Old May 2, 2004 | 10:14 AM
Default Re: (elevatethis)
bump
Old May 2, 2004 | 10:16 AM
Mag00n's Avatar
This is a little depressing since my best is a 15.5 with b16a3. That was pre-boost of course.
Old May 2, 2004 | 11:45 AM
Jimmy's Avatar
Global Moderator
Run with 19-20 psi in your tires and lower your '60's.
Old May 2, 2004 | 11:47 AM
spnfed's Avatar
What size wheels were you running?
Old May 3, 2004 | 09:46 AM
Default Re: (spnfed)
stock alloy 14's with michelen tires
I'm feeling somewhat satisfied considering that honda says a stock del sol si will run 16.7...but like I said, if I could get a tenth of my 60ft and figure out whats best to do top end (stay in 3rd or shift to 4th) i think i could see a 15.9, not too bad for a d series with bolt ons, stock drivetrain, street tires, no weight reduction...
Modified by elevatethis at 2:19 PM 5/3/2004
Old May 3, 2004 | 12:58 PM
bump for the day job h-t crew
Old May 3, 2004 | 02:06 PM
cxjon's Avatar
seeing times liek yours in heavy car makes me think i can break in to the 15's with my d15b vtec :D
Old May 3, 2004 | 02:34 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: (cxjon)
that's not bad at all. i remember someone else on these boards only running a 16.1 with a del sol VTEC (B16). just bring those 60' times down and you'll be in the 15s.
wrx'n you
Aug 13, 2005 08:16 AM
PA MATT
Aug 20, 2004 08:10 PM
sting94112
64
Mar 28, 2004 03:12 PM
Adi Radoncic
Sep 1, 2002 11:37 PM
mikeSONICGSR
Nov 5, 2001 07:02 PM
