Should I upgrade to bigger fuse after new horn install?
Old Apr 30, 2004 | 08:44 PM
zither's Avatar
Default Should I upgrade to bigger fuse after new horn install?
I installed one of these new horns, sorry for hotlinking to the vortex, http://forums.vwvortex.com/zer...age=1. Today I installed the horn and used it quite often but after holding it for a while, the fuse burned out, it's a 15A fuse and I'm wondering if I should upgrade it to a 20A since the horn is bigger. For those of you not familiar with the civic's original horns, it's a small disk.
Old Apr 30, 2004 | 09:02 PM
JDMlyfestyle's Avatar
according to that link its a 10 amp. you might be hurting it by putting in a bigger fuse
Old Apr 30, 2004 | 09:10 PM
PariahBoardshop's Avatar
Default Re: Should I upgrade to bigger fuse after new horn install? (zither)
well did the fuse just melt or did it pop? i havent clicked on the link but if it does says 10 amp, then you might have a problem somewhere else. (short)
Old May 1, 2004 | 10:30 AM
zither's Avatar
Default Re: Should I upgrade to bigger fuse after new horn install? (eternalek)
It burned out, melted i guess. It's hooked up just like the stock horn, the one wire from the stock horn goes to the positive end on the new horn and the negative on the new horn goes to the chassis, it's just held to it by a screw, everything else is soldered. It worked for a while it burned out later on after i pressed the horn button for a longer period. Also the stock fuse is also for something else, on the cover it says "HORN, STOP".
klite24
Oct 14, 2013 04:35 PM
CheddarPopcorn
Jun 30, 2009 10:53 AM
infinity257
Audio / Security / Video
11
Jul 20, 2004 08:01 AM
Bucktown
Mar 8, 2004 06:11 PM
specv5150
Feb 23, 2004 05:26 AM
