Fuel cut off at 7500rpm & engine light
I have a 91 CRX with a B18C5 motor, every once in a whyle the car will bogg around 7500 and the check engine light will come on, when i re-start the car, the engine light go's off. Maybe a misfire????? when i check the jumper to see what the code was, nothing comes up. I am running a stock HF fuel pump with the engine, i am trying to eliminate what the problems could be before i buy a higher flow pump.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DohcVtec1.6-1992 »</TD></TR><TR><TD CLASS="quote"> I am running a stock HF fuel pump with the engine ....</TD></TR></TABLE>
I'd think this is probably part of your problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed »</TD></TR><TR><TD CLASS="quote">
I'd think this is probably part of your problem.</TD></TR></TABLE>
agreed...
have you ever dyno'd/tuned your car?
agreed...
TnLude2000
Feb 26, 2005 12:25 PM
