P73 ECU on a B16A2
Will a P73 ECU work on a B16A2?
What will be needed for this to work; will a VAFC do the job?
Also, what kind of benefits can be had from this.
Thanks for the help in advance
Modified by Mr_GaBIG at 3:29 PM 5/5/2004
it will run the motor but depending on year and type :
1)extra sensors might be required
2)my not be plug in
3) there also might be an imoblizer.
there is too many details missing from your question, simply to vague
2)my not be plug in
if the car is obd2 you can plug & play. not sure bout the immoblizer though.
you get different ignition maps/fuel maps
higher red line & different vtec engagement(higher rpm) 6 i believe.
StanleyScotland
Jun 14, 2010 06:42 PM
