SUSPENSION?? VIBRATIONS!!!!
Old Apr 30, 2004 | 05:59 PM
boostin4door's Avatar
Default SUSPENSION?? VIBRATIONS!!!!
This is probably a stupid *** question but my dumb *** cant figure whats going on here... just recently swapped my 4 speed ef hatch with a b16.. and put 92-95 suspension in it with the 92-95 wishbones so they would fit.. cause the bottoms are fatter then a ef strut.. but anyways.. theres a strange vibration that is annoying as **** when i drive it.. mostly when im driving when i give it gas.. i checked all the ball joints, the spindle, the radius rod and tie rod connection just to make sure they were all tight which they are... but it vibrated the whole entire car to the point where i dont even wanna drive the thing.. and oddly enough it stops vibrating when i turn to the left or make a left turn... if anyone knows whats up please let me know
Old Apr 30, 2004 | 06:12 PM
BenCrx's Avatar
Default Re: SUSPENSION?? VIBRATIONS!!!! (widebodyjaeg16b)
I'm not postive but it sounds like it's your wheel bearing, is next time you turn right listen for a thumping sound in may be very faint, but if you here it, it's your bearing
Old Apr 30, 2004 | 06:21 PM
Default Re: SUSPENSION?? VIBRATIONS!!!! (BenCrx)
yea i dont think its as bad when i turn to the right either but.. it still vibrates..
Old Apr 30, 2004 | 08:03 PM
90civichbsi's Avatar
did you take the dust rings out of the spindles? if your useing the 90-93 integra intermediate shaft and axles you have to do this or it will cause your axles to bind... and shake under acceleration
hispanic panic
Sep 30, 2011 01:13 PM
SinglecamMitch
Aug 30, 2008 02:01 PM
hybrid90
Suspension & Brakes
14
Feb 27, 2008 03:35 PM
Eggman
39
Mar 31, 2005 04:29 PM
evad
Dec 6, 2004 09:28 AM
