Help: Tachometer isn't working!!!
I swapped my ITR Motor into my car and the RPM gauge isn't working. I checked the plugs where it goes to... Tranny Plug, Distributor, and the Cruise control. Everything is plugged. I was wondering if there is a fuse that controlled the RPM gauge that might of blown. Please Help.
-Q
-Q
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm wannabe »</TD></TR><TR><TD CLASS="quote">most older cars require an rpm output from the distributer while newer(00-01)
did not. check the blue wire at the distributor plug</TD></TR></TABLE>
YES like he said wiring could be slightly different, dont sweat it ... it will work out..
The Vtec Still engage. You can definitely tell. Its just the RPM Gauge that is not working... Thanks for the help.
-Q
-Q
topshotta
10
Mar 31, 2016 07:55 AM
l1bid0
21
Nov 8, 2006 05:04 PM
mr6sr
Nov 30, 2004 03:31 AM
