Replacing Clutch Master and Slave Cylinders
Old Apr 30, 2004 | 05:10 PM
I20I3's Avatar
Default Replacing Clutch Master and Slave Cylinders
Do I need a flare wrench to get the fluid lines off. And is there anything else special that I would need?
Oh if I do need a flare wrench can you please give me the size that it needs to be (?mm)
I have a 1994 Accord EX btw.
Old Apr 30, 2004 | 06:48 PM
tommymoose's Avatar
Default Re: Replacing Clutch Master and Slave Cylinders (I20I3)
Yeah, you do need a flare wrench. I tried to use a regular wrench on the hydraulic line on the slave cylinder and I ended up rounding it off the slightest bit, creating tiny burs, so when I went to use the flare wrech it didn't even fit on. I can't remember for sure, but I remember it was either an 11mm or 12mm that you need.
Old Apr 30, 2004 | 09:09 PM
layzi3's Avatar
Default Re: Replacing Clutch Master and Slave Cylinders (tommymoose)
i just got that done todai
its a B**** doing it and make sure u get all ur air out
Old Apr 30, 2004 | 09:11 PM
layzi3's Avatar
Default Re: Replacing Clutch Master and Slave Cylinders (layzi3)
o yea don't take out ur spring by the clutch pedal
gonna take u awhile to put back in
coltonjamesb
Honda Civic (2001 - 2005)
Nov 1, 2012 03:50 PM
LilTeggy2011
Apr 27, 2010 06:43 PM
R81_DC2
Aug 14, 2009 08:54 PM
92GSR HB
Sep 29, 2008 01:36 PM
revhigh89
Feb 15, 2004 03:10 PM
