Front motor mount stripped need help
Old Apr 30, 2004 | 11:46 AM
matix's Avatar
Default Front motor mount stripped need help
Ok the threads on the block itself are stripped. Is there a good way to fix this or re thread it. What would be the best way for me to fix this so my motor mount doenst keep coming loose causing bad axle bind.This is on a h22 block. It is the bottom bolt that wont tighten i think its a 10x40.
Old Apr 30, 2004 | 02:42 PM
doublejz's Avatar
Default Re: Front motor mount stripped need help (matix)
helicoils or timecerts
helicoils you need some thread left for the repair to stay
timecerts you will drill out the threads and put in an entirely new insert that will be threaded in.
timecerts
Old May 1, 2004 | 10:01 AM
matix's Avatar
wich timesert kit do i need for this bolt. http://www.timesert.com/mtrcsert.html
Old May 1, 2004 | 01:00 PM
matix's Avatar
bump i cant drive
shytdoode
Jun 24, 2009 10:35 PM
Herminator
Welding / Fabrication
Oct 22, 2005 04:00 PM
al3e
Jun 5, 2005 09:13 AM
gsrcivic619
Apr 8, 2004 05:30 AM
00WhiteEKy
May 30, 2003 10:09 AM
