Do I need the T.P.S (throttle postion sensor)
Old Apr 30, 2004 | 07:15 AM
rhemu1's Avatar
Default Do I need the T.P.S (throttle postion sensor)
I have a 90 accord and I am putting a jdm h22a in it when i got it the throttle position sensor way broke off it do I need it or will my motor be fine without it??????????
Old Apr 30, 2004 | 07:55 AM
brads94accord's Avatar
im pretty sure your idle will be pretty whack without it. just buy a new one from hondaautomotiveparts.com
Old Apr 30, 2004 | 07:16 PM
Nathan007's Avatar
You will need it, it may be used by the ECM for injection (air/gas mix)
Old May 1, 2004 | 08:39 AM
FatJoe's Avatar
Default Re: (Nathan007)
basically without it..ur car could think ur flooring it when really its suppose to be idling....hence the throttle POSITION sensor name....
Old May 1, 2004 | 09:20 AM
jakks20's Avatar
Default Re: (FatJoe)
Or....you could just use the one from your f22. Take a dremel and grind a screwdriver slot in to the 2 rivets that hold it on. Remove with a screwdriver and put it on the h22. I had to do it with mine, but I just got one from an old Civic hatch motor. You will have to set once you get everyting hooked back up though. I can't remember the voltages rigth no though. 0.5 shut throttle and 4.5 WOT I think....
gripek
Honda S2000
12
Feb 22, 2012 10:08 PM
nutball72
Nov 11, 2006 07:14 PM
Achenar
14
Jul 15, 2005 03:27 PM
SprayinCX
Aug 2, 2003 09:49 PM
sivik2nr
Aug 24, 2002 07:02 AM
