moonroof/sunroof issues.... psssh....
Old Apr 30, 2004 | 01:57 AM
projektCRX's Avatar
Default moonroof/sunroof issues.... psssh....
hey would anyone happen to ever come across this problem.
Basically the moonroof opens sometimes, and not always.... weaksuace!
its hella ghetto. sometimes if i push the moonroof up it will open but thats only 60% of the time.
heres what i've tried, ive greased up the rails like a motha...and i even swapped out the motor.. the switch works, cuz it turns the motor forward or backward. and the fuse isnt blown..
ANY IDEAS???
Old Apr 30, 2004 | 03:04 AM
Skunk.Werks's Avatar
Default Re: moonroof/sunroof issues.... psssh.... (projektCRX)
I'm not a wizard on how moon/sunroofs work (mine doesn't even work) but I would assume since you replaced the motor, that you are gonna have to look at the thing more closely. You might have to pull out the headliner to get a nice look at the rails and moving parts etc..
Old Apr 30, 2004 | 07:56 AM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projektCRX &raquo;</TD></TR><TR><TD CLASS="quote">hey would anyone happen to ever come across this problem.
ANY IDEAS??? </TD></TR></TABLE>
I know you tested the switch but try a different one.. sometimes they are intermittent..
Old Apr 30, 2004 | 08:44 AM
APEX CRX's Avatar
mine did that too. believe me. REPLACE the switch. even if it works sometimes the switch might be going bad. Go buy a new one. Its the easiest thing to do next to find the problem. If its not the switch at least the picture on the switch will be new!!
Old Apr 30, 2004 | 09:19 AM
2point2's Avatar
Default Re: moonroof/sunroof issues.... psssh.... (APEX CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by APEX CRX &raquo;</TD></TR><TR><TD CLASS="quote"> If its not the switch at least the picture on the switch will be new!!</TD></TR></TABLE>
haha.. i love when the 'pictures' are new..
Old May 2, 2004 | 04:16 PM
projektCRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by APEX CRX &raquo;</TD></TR><TR><TD CLASS="quote">mine did that too. believe me. REPLACE the switch. even if it works sometimes the switch might be going bad. Go buy a new one. Its the easiest thing to do next to find the problem. If its not the switch at least the picture on the switch will be new!!</TD></TR></TABLE>
ill have to do that...so im assuming honda will still be able to sell that...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skunk.Werks &raquo;</TD></TR><TR><TD CLASS="quote">I'm not a wizard on how moon/sunroofs work (mine doesn't even work) but I would assume since you replaced the motor, that you are gonna have to look at the thing more closely. You might have to pull out the headliner to get a nice look at the rails and moving parts etc..</TD></TR></TABLE>
yah i was thinkin about that...cuz it doesnt seem as firm as it should be...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 &raquo;</TD></TR><TR><TD CLASS="quote">I know you tested the switch but try a different one.. sometimes they are intermittent.. </TD></TR></TABLE>
that one part i didnt replace... so ill try that..
thanks everyone for your input... ill post any results !
Old May 2, 2004 | 04:22 PM
t0eKnEe's Avatar
I have a spare switch withl all the wiring uncut if your interested. pm me if so.
Old May 2, 2004 | 04:47 PM
projektCRX's Avatar
Default Re: (t0eKnEe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0eKnEe &raquo;</TD></TR><TR><TD CLASS="quote">I have a spare switch withl all the wiring uncut if your interested. pm me if so.</TD></TR></TABLE>
i imed y0u. but yah if im interested in the switch, if u dont mind mailing it. =p
Old May 2, 2004 | 04:52 PM
SunkistRex's Avatar
Default Re: (projektCRX)
put some lube on the rails.. and then open and close it like 4 or 5 times, then put some more lube.. i hear **** lube works best.. haha j/k i see that u tried the lube.. but pull that bitch out and clean the rails, and lube it up.. i bet that bitch will skeet open like cockroaches when the lights come on
Old May 2, 2004 | 05:09 PM
manson's Avatar
Default Re: (SunkistRex)
i would put it on the switch. my buddys was the same way...then i pulled my switch out placed it in his car and it worked perfect.
there shouldn't be any wiring to do for the switch... you just plug and play.
Old May 2, 2004 | 06:39 PM
projektCRX's Avatar
Default Re: (mansonclubpuir)
yayuh! now all i need is a switch =p
Old May 2, 2004 | 06:40 PM
Rob.'s Avatar
It could be the switch... Inside it , is weak.
Old May 2, 2004 | 06:50 PM
Eresuncabron's Avatar
Default Re: (ROB89M3)
Dude don't get a new switch unless they are cheap. u can definately take them apart and clean them...
once u get it apart u will c black stuff on the contacts... wipe it off.
I hope thats helpfull
Old May 2, 2004 | 07:03 PM
my car sucks84's Avatar
Default Re: (Eresuncabron)
i had the same problem, i cleaned the switch and it still didnt work. so i put a new one in the other day, and it works great now. hope this helps
Old May 2, 2004 | 07:07 PM
projektCRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by my car sucks84 &raquo;</TD></TR><TR><TD CLASS="quote">i had the same problem, i cleaned the switch and it still didnt work. so i put a new one in the other day, and it works great now. hope this helps</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ROB89M3 &raquo;</TD></TR><TR><TD CLASS="quote">It could be the switch... Inside it , is weak.</TD></TR></TABLE>
you kno? i never thought of that. ill try that first......
how much was the switch at honda?
Ivan's Avatar
senior gold member
hmm Thats weird. I would also think its the switch. Mine opens but doesn't close I gotta find a switch too.
slow_cx
Dec 29, 2007 04:56 PM
IneedBoostInTheCoupe
Dec 16, 2006 03:48 PM
ImportechPerformance
11
Dec 13, 2004 11:39 AM
lsvteccoupe
Dec 9, 2004 04:54 PM
J Money
14
May 1, 2003 06:29 PM
