tire rubbing question with picture
Old Apr 29, 2004 | 10:15 PM
georgelb's Avatar
Default tire rubbing question with picture
Ok, I searched...but did not find this particular problem.
I have 205/15 azenis on 7" wide rims and only the front passenger side rubs like this.
I am thinking it could be alignment related. I have a front camberkit on backorder from Wiredspeed, so I have been driving around without the alignment. I raised the front up about a quarter inch to a tight two finger gap, and the rubbing dissapeared. It also rubs on the top with it any lower than a tight two finger. Springrate is 7k linear.
Should this clear up when I get an alignment? And why would it only do this on the passenger side?
Thanks for any help.
Old Apr 29, 2004 | 11:36 PM
91DA9's Avatar
Default Re: tire rubbing question with picture (georgelb)
Sound's like the alignment to me. You change the suspension geometry when you lower your car.
Old Apr 29, 2004 | 11:40 PM
georgelb's Avatar
Default Re: tire rubbing question with picture (91DA9)
Yeah, I know...but I do not want to take it back down..shell out the cash for an alighment, and have it still rub. I would then have to raise it back up and get it aligned again.
Old Apr 30, 2004 | 05:35 AM
Muckman's Avatar
Moderator in Chief
I bet you a camber kit might fix that... How much are you lowered?
Old Apr 30, 2004 | 08:20 AM
Imprezor's Avatar
Default Re: tire rubbing question with picture (Muckman)
Algnment
Old Apr 30, 2004 | 08:49 AM
APEX CRX's Avatar
> what is the offset of the rim you are using?
Old Apr 30, 2004 | 10:14 AM
georgelb's Avatar
Default Re: tire rubbing question with picture (APEX CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">I bet you a camber kit might fix that... How much are you lowered?</TD></TR></TABLE>
Not sure how much lower than stock. It is 23.5" to the top of the center of the front wheelwells. Starts rubbing at 23.25"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by APEX CRX &raquo;</TD></TR><TR><TD CLASS="quote"> &gt; what is the offset of the rim you are using?</TD></TR></TABLE>
40mm
Old Apr 30, 2004 | 10:15 AM
georgelb's Avatar
and again...it is only the front pass side.
Old Apr 30, 2004 | 10:23 AM
APEX CRX's Avatar
hmm thats weird, I run 15x7 Slips with same size and offset and my car is pretty low as well. It does not rub on the insides at all. It did rub when I had 45mm offset rims. Best bet is to get the alignment checked with the camber kit installed to make sure nothing is bent.
Old Apr 30, 2004 | 10:34 AM
Muckman's Avatar
Moderator in Chief
Everytime I get an alignment the driver side and passengerside wheels never have the same camber. One wheel could be off as little as .5* and make all the diffrence in the world.
Old Apr 30, 2004 | 10:35 AM
georgelb's Avatar
Ok, then whenever my camber kit finally gets here I will drop it back down and go get an alignment.
Thanks guys
osix
Nov 21, 2015 10:43 AM
Jdmgarret11
Jan 17, 2012 12:14 PM
slow_ls
Dec 15, 2006 08:42 PM
djsire
Jan 21, 2006 03:47 PM
FK00GSR
Apr 17, 2003 12:18 PM
