welder question....
Old Apr 29, 2004 | 10:07 PM
s1ngle's Avatar
Default welder question....
I have an opportunity to get my hands on a welder, but its a "spot" welder.
How is this different than a normal one? Would i be able to weld, say, downpipes with this welder?
any help is appreciated.
Old Apr 29, 2004 | 10:11 PM
tominos's Avatar
Default Re: welder question.... (s1ngle)
spot welder? aren't those the kind you just step on, and two points come together and weld two pieces of sheet metal?
b/c all types of welders can spot weld, i think it's where you just tack it on, or is that a tack welder?....
i dunno, someone help this guy out.
Old Apr 29, 2004 | 10:19 PM
elwood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s1ngle &raquo;</TD></TR><TR><TD CLASS="quote">I have an opportunity to get my hands on a welder, but its a "spot" welder.
any help is appreciated.</TD></TR></TABLE>
Im no expert on welding by any means. Im young, and havnt been
around a lot of it, so im not too sure as to whats all out there. I didnt
know there was a specific machine just for spotwelds that any normal
person would have. Seems like more of a body shop applications.
I know you wont be able to weld downpipes and exausts, you would
need a constant beed, where the spotwelder would be just a spotweld,
like you find on your firewall.
Thats assuming the "spotwelder" can only be used for spotwelds.
Old May 7, 2004 | 12:03 PM
LudeyKrus's Avatar
A spot welder will have a big set of arms that reaches around sheet metal so it can spot weld them together.
It is just used to join sheetmetal together; it is more than likely not what you want.
Old May 7, 2004 | 01:09 PM
jolt-tsp's Avatar
Default Re: (LudeyKrus)
You will want a mig welder to weld downpipes and stuff
Old May 7, 2004 | 05:53 PM
TeamCracka's Avatar
Default Re: (jolt-tsp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jolt-tsp &raquo;</TD></TR><TR><TD CLASS="quote">You will want a mig welder to weld downpipes and stuff</TD></TR></TABLE>
Any type of welder will work fine for welding small diameter steel tubing. TIG will always be the cleanest, and since most mandrel pipes ppl buy are aluminized steel, the MIG will have to have the correct wire/gas in it.
TIG
Old May 10, 2004 | 09:02 AM
jolt-tsp's Avatar
Default Re: (TeamCracka)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamCracka &raquo;</TD></TR><TR><TD CLASS="quote">
TIG </TD></TR></TABLE>
definitely, if you have the green
siblues
Welding / Fabrication
Jan 19, 2008 01:39 PM
92EG8
Nov 20, 2006 08:09 PM
needforvtec
Jul 15, 2006 11:53 AM
92CivicSIRhb
25
Aug 28, 2005 02:30 AM
nitekidsef9
15
Dec 27, 2004 04:07 PM
